Header and torque converter install - advice and install
I wasn't gonna go ape this year on car mods cause I was kickin' around getting a different car entirely. But after realizing how close I am to paying the rig off...we're keepin it. 'Figured if I could nab a mod or two this year I'd be happy. ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Anyway, so I stumbled on a used but cracked set of S&S headers and have since had them TIG welded the CRAP out of my a machinist. Just gotta buff a couple areas they should be good!
THEN I came across a good deal on a Lextreme torque converter. Uh, DUDE.![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
Just bananas. Arguably the 1st and 2nd bang-for-your-buck mods, and picked up pretty cheap, I'm excited as H-E-double hockey stick to install the stuff!! But, since I'm Kenny-on-South-Park poor, I gotta install myself. Which is cool, cause I enjoy knowing I did something I didn't think I could, and I know "I"s were dotted and "T"s were crossed in the process.
_____________________
So I'll take a few pics of the process, and hope to add to the pile of great feedback from these mods.
Any advice that can be offered is appreciated. "Don't get yourselves killed" is probably a given.
I've been searching off and on, but in case I missed something, lemme think aloud and please chime in if I missed/forgot somthing.![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
Geez those smileys are fun...just look at 'em all.
- Headers:
- Ordering new manifold-to-block gaskets which I'll port-match to the headers.
- Bolt torque specs?
- IIRC extra bolts are needed for the headers...qty/size known?
- Torque converter:
- Will have a fair amount of Toyota tranny fluid on hand (not sure how much) and a 5-gal Homer bucket to catch the old stuff in.
- Ordering a tranny gasket at the bell-housing ("rear main seal", right?).
- I'll borrow a ratchet extension from work for the hidden tranny bolts.
I'm going to be dropping my transmission tomorrow to rebuild it. I'll TRY to do a DIY on removing the transmission and installing the TC. I'll post it up on my website. I better be getting some donations on my website this time around or I'm never renewing the site ever again lol. It costs me $60 or so to keep the website up every year!
GSJake: 2800 RPM...I think. I still have a day or two to change my mind. NEO or AFC2 and a tune is definitely down the pipe (I'm'a race Rock-a-Lex one of these days!! Haha!), but its the wife's turn next so I gotta hold off a bit. And you know WI -- wish me luck finding a dyno much less a shop that knows anything about the 1uz! When I find one, though...
Jeff: That would be MUCH appreciated. What's the web address? (edit: jefftsai.com) You get 'er done and I'll donate. For the record, though, $60 for you is like one of your gear cog sprag spring nubber thinges, so I don't feel bad.
But...I did the website for the benefit of everyone else here. I don't really have any need to have a website for myself since it's all in my head already. That's $60 out of my pocket to benefit everyone else that I could of bought some food and drinks with
Jeff as in the PM count me in for some web site contributions.
Also while you have the tranny out.. can you do a VB DIY. I am still considering this even though every one says its way harsh.
Frank.. Yea you will not find one in WI. You will have to go to Chicago and then you have AMS and a few others. I will keep you posted as I have my Neo.. saving for a boomslang on here and then I will be going for a few base runs with just a Injen and some Borla's.
Sam430, I use impact guns and a really long extension to get to the transmission bolts on top. You don't really need small hands as you don't ever really have to reach all the way up in there.
Vwynn, yes pretty much the same. Only difference is that the 400/430 has two headers that you have to disconnect the exhaust pipe off of.
Jeff, I was talking about the headers
I just put on my headers a couple of days ago and it took me 8 hours due to allergy and the cat not lining up properly (took me forever bending, pushing, and pulling until I can insert the bolt).
It's very easy to take on and off the OEM headers (granted you've already removed the heat shield).
The SS headers is just a tad more effort to install one bolt on the bottom driver side towards to the stearing wheel. Make sure to put that nut in first before you tighten things down.
If you can find someways to cut the heatshield, you job would be easy. But use wobble extensions to take it off easily. Also remove the side plastic cover for the sway bar so it's easier to manuever your tool to get the other bolts.
I took a peak at the top bolt of the transmission, it's not so bad. But everything is easier said than done.
The effort pays off... I forgotten how much I enjoyed the extra power from the headers, I could only imagine FI LOL. With just a touch on the pedal, the car was eager to go.
DrewGS4
Suspension and Brakes
07-29-04 05:43 AM
