GS300 changed spark plugs to TM plugs & now code P0154, vsc, vsc off light, abs light
Old 12-21-13, 08:49 PM
GregCon
GregCon's Avatar
Well, after some messing around I fixed the issue so I thought I would post the fix here as a follow up.
The car was showing a P0154 code which is no activity on the Bank 2 Sensor 1.
I used the scanner to watch the STFT and O2 sensor voltage for the Bank 2 Sensor 1 O2 sensor and in general the numbers were not what they should be...in fact they were either 0 or barely above it for the voltage, and there was a lot of STFT correction going on which meant the computer was trying to richen up the mixture to compensate for no inputs from the O2 sensor.
I replaced the sensor with a new Denso unit and the readings were good for a few miles, but then they degraded quickly and the CEL and VSC lights came back.
I started looking at the wiring harness, where the O2 sensor plugs in, and it looked perfect. It was not something I disconnected during the plug/valve cover gasket change, either. But then I pulled on each of the 4 wires and one came right out of the connector. I pulled the terminal out, and you could see where it had been over-crimped when new. In fact, it looked like it spent the past 8 years and 121,000 miles working by proximity contact only. I am sure the work I did caused the harness to move a little which was just enough to move the wire out of contact.
So, I soldered the terminal box on to the wire (you can't recrimp this type of terminal) and it works great now. No more lights.
The connector/terminal arrangement is really dainty for an underhood part, IMO. If it ever gives trouble again I will replace the entire 4 pin connector with a 4 pin GM-style Weatherpak connector which uses a mechanically stronger terminal and is easy to buy. But for now it is working well and I doubt it will break again.
Beryce (10-16-20)
Old 08-13-18, 11:22 AM
kayuwong
kayuwong's Avatar
Default P0154 after valve cover job
Can anyone help me out on this issue, I even changed B2S1 sensor and still get chk engine light.
Old 01-07-19, 01:17 PM
DuckyB
DuckyB's Avatar
Default Ecu
I had the same issue and code. After replacing Bank 2 Senor 1 with no cure I took to the dealer . Banks 1 & 2 Downstream sensors and ECU are bad. very expensive repair, if taken to a Dealer
Old 01-07-19, 02:29 PM
kayuwong
kayuwong's Avatar
Default Use a safety pin to check circuit
Old 01-07-19, 02:38 PM
kayuwong
kayuwong's Avatar
Default Wire was broken inside of the harness
My mechanic broke the wire by flipping the TB on the side without disconnecting the harness, it took me a long time to find out the problem. Wiggle each wire and pull gently and test, I end up just replace that pin inside the wire harness, good luck.
Nickib
12-13-15 05:31 PM
Jayd41
05-21-14 09:26 PM
chico55
05-15-14 08:24 PM
98lexgs300
06-21-13 09:39 PM
ZeekGS300
07-28-10 09:35 AM
Quick Reply: GS300 changed spark plugs to TM plugs & now code P0154, vsc, vsc off light, abs light
