it is possible to swap motor??
anyone know if it is possible to swap motor in gs400??? i'm planning to get a 99 gs400 and swap it to 2jz.. has anyone done it before and how hard it is?? it the transmission in gs400 same as gs300??
why not a GS300 to start with? The difference between 300 and 400 can probably save you 1/2 on the swap.
It's most likely doable. Tranny should be the same. ECU too just different wiring diagram. But if you want to swap 2JZ-GTE you should replace the tranny also (either Supra 5-speed or Aristo 4-auto). Don't think 2JZ-GTE will work with the US-spec 5-speed auto. Doesn't exist in Japan with this combo.
or you can go crazy and put a 6 speed now that would look real nice
you could also try...
If you can find a wrecked Aristo V300 (unlikely) with a perfectly good front end (highly unlikely) the cheapest route to go would be to switch the entire front clip rather than doing the engine swap/fitment alone because it should come entirely with everything you need, tranny, ecu... etc. It's an option but it's not likely unless you have the hookups.
That is all.
That is all.
by the way do you guys think the engine from 99 gs400 will work in 95 sc400?? i found a high millege 95 sc4 and low miles 99 gs4... i plan to put the gs4 engine into older sc4 and do a 2jz swap for gs4.. i might pick up both cars next week so i want to see what my options are..
Originally posted by splitfire
that's what i thought but it wasn't easy to find one...call serval place no one has them... also looking for used 2jz from a wrecked supra ask serval shops i got not even one phone call back... i'am still waiting for price quote on new 2jzgte..
Damn!!
ok i have one more question i hope you guys can help, lets say i get the gs300 and found a 2jzgte from a US 95 supra with the auto transmission.. what else do i need to get it to work in a gs300 in addition to that???
i work at burger kiing.. anyone need a job that pay minumum wage??
I'm also interested in knowing what company you are working for
in another words your GS will be a shell with a Supra engine. That's just plain weird. I would strongly suggest you find a V300 front clip. With your connections it shouldn't be too hard. If you can manage to get one of those, the rest will be a walk in the park.
