Anyone with Cat Converter issues answer me this...
Old 02-15-11, 10:18 AM
EN_VY
EN_VY's Avatar
I wouldnt recommend buying used, same thing is going to happen again eventually. If anything, buy aftermarket headers and call it a day.
Old 02-15-11, 11:01 AM
GS4_Fiend
GS4_Fiend's Avatar
Originally Posted by JeffTsai
Best to look around junkyard or forums. You can find a used cat for around $100-150 or so. It uses the same one as the IS300 as well, so you can search for the cats for that car instead for more results. Also, the cats cost so much because they come welded onto the exhaust header on the car.
It is Illegal to sale used catalytic converters.
Old 02-15-11, 11:16 AM
Ceezo
Ceezo's Avatar
its illegal to sell used cats in cali, i usually have them shipped to my bud in texas and then send them here haha
Old 02-15-11, 06:53 PM
ONESON
ONESON's Avatar
I have a 03 GS300 and I had to replace mine last Sept. The problems is that the cat for these cars cost $1000-$1200. Every where I looked and called, I got the same result. So, I just bit the bullet. But, it is cheaper at toyota opposed to Lexus. And, by the way, make sure you know which one it is. GS's have 2.
Old 02-15-11, 09:34 PM
miaristo
miaristo's Avatar
+1 This is what I did bout to months ago.
Old 02-16-11, 04:55 PM
jeepandlex
jeepandlex's Avatar
funny I got a p430 code for a cat, bank 2, but still passed emissions???
Old 05-10-11, 08:39 PM
nasgs430
nasgs430's Avatar
having the same problem just tried to replace the cats on my 01 gs 430 but i bought used one off a 03 thought it would fit but nope not my luck i need help my self if u got it fix for cheap let me know
Old 06-01-11, 07:38 AM
98sleeper
98sleeper's Avatar
Well my P0430 CEL kept coming on. I've run 4 bottles of injector cleaner back to back (chevron Techron concentrate - not fuel injector cleaner) and this morning the light went off by itself. **** Crossing Fingers **** I'll run it through the epa city cycle and post again if it goes out - maybe i've cleaned it - maybe not but it's worth a try.
Old 06-01-11, 03:22 PM
spdrcr771
spdrcr771's Avatar
My passenger cat is bad, so I sourced a couple of people that will sell me a used stock cat for my 98sc400. Was gonna get 2 for $200 shipped, but then Paul @ PPE talked me into buying the Magnaflow universal high flow cats that they offer. They have a 5yr warranty paper that comes with them. What ever shop installs them, fills out the paperwork & eather YOU or THEM sends it back to Magnaflow. Magnaflow's web site sells them for like $235-250 but you cant buy them on Ebay for $78.90, at least thats what I paid. But your exhaust guy will have to cut the flanges off you old cats & weld them to the new ones. Or you can get Paul @ PPE to sell you new c&c cut flanges.
Old 06-02-11, 09:49 AM
GS4_Fiend
GS4_Fiend's Avatar
In ethics, what monitors the cats and triggers the code? The pre and post oxygen sensor compares values and sends the signal to the pcm so it gets updated information. So, if the oxygen sensor is defective, it will send false signals to the pcm in a result bad cat. I suggest you check out if the oxygen sensors are properly working first before changing cats. just saying.
TTBomB
03-03-23 11:12 AM
6chuchu6
IS - 1st Gen (2001-2005)
10-11-12 05:51 PM
mex lex
01-26-07 07:01 AM
kaisermhw
03-21-04 07:40 PM
Quick Reply: Anyone with Cat Converter issues answer me this...
