All Aluminum Radiator for the GS430
Request
1)Pictures
2)Radiator model & ~cost
3)~Weight difference between stock.
4)Differences between stock and difficulties of install and what to watch out for. Example, need custom electric fans, need more space, need to relocate something etc...
5) Tranny cooler options.
There is a thread on gs300 here.
1)Pictures
All you guys are on 5 speed? Is there a connection for the automatic tranny fluid on those all aluminum radiator? Doesn't look like any of them provides cooling for auto tranny. So someone must have another cooler for the tranny with an electric fan, otherwise, the tranny will run hot.
I currently have an external tranny cooler but it's not fan activated. It runs in sequence after the stock tranny cooler. Looks like there are some sales on temp activated electric cooler.
I might do this... but a little different. I will cut into the metal piece and push the radiator forward to provide more room for future upgrade
I might do this... but a little different. I will cut into the metal piece and push the radiator forward to provide more room for future upgrade![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Yeah unfortunately I have to use pusher fans (zirgo 16" x 2), which are not as efficient as a puller fan to help cool the radiator. But what ya gonna do when I can't relocate the twin snails without doing major reworking.
Hi guys, will this be sufficient for the gs430? It appears the inlet of the aluminum is smaller than oem. NVM, I searched and found some mkiv ones that are even cheaper than these.
MMRAD-IS300-01
Core Size: 375mm x 708mm
Rows: 2
Inlet: 35mm
Outlet: 35mm
Core Thickness: 36mm
Tank Wall Thickness: 2mm
Fill Neck : 32mm
I will look at the oem spec later today. Don't know if the inlet outlet are the same size or not.
oem spec will compare later:
Brand: Replacement
Condition: New
Endtank Material: Plastic
Engine Oil Cooler: No
Inlet Size: 1.5 in.
Outlet Size: 1.5 in.
another
Automatic Transmission Cooler: Yes
Core Dimensions: 15-3/4 x 29-13/16 x 5/8 in.
Core Material: Aluminum
Inlet Size: 30-5/16 x 1-9/16 in.
MMRAD-IS300-01
Rows: 2
Inlet: 35mm
Outlet: 35mm
Fill Neck : 32mm
Brand: Replacement
Condition: New
Inlet Size: 1.5 in.
another
