Fidanza flywheel + Spec clutch
Old 03-14-11, 11:48 AM
  #31
mikeho
mikeho's Avatar
Originally Posted by Moto
Also when i was going up hill and starting back out in first i was getting almost a screeching noise coming from the transmission.
I was getting that ever since I drove on hills in San Francisco. Talked to my mechanic; basically, he said that the heat from the friction from riding on the clutch on the hills has changed the clutch material. In essence, it's hardened the clutch, causing that screeching noise.
I still get it from time to time, especially on hills, but from what he told me, it's nothing dangerous or bad on the transmission.
Old 04-22-11, 08:15 AM
  #32
B16da9
B16da9's Avatar
So I purchased this flywheel flywheel new from Rob and I only have one question. Did any of you change the rear main seal while you where in there?
Old 04-23-11, 11:00 AM
  #33
pepos
pepos's Avatar
i did
it had a small leak which is normal after some miles
Old 08-10-13, 08:16 AM
  #34
arpegius
arpegius's Avatar
PDF File link has changed - now at:
http://is.sewellparts.com/pdf/PTR1553080.pdf
pepos
Performance
27
04-14-15 11:38 PM
93sc3005sp
Performance & Maintenance
01-01-09 01:17 PM
dinhnerz
07-11-07 12:53 AM
ScTHREE
08-24-06 12:28 AM
VincentLex
02-13-06 05:09 PM
Quick Reply: Fidanza flywheel + Spec clutch
