New Project for twin Supercharge
I apologize Kurtz. I shouldn't have said anything to begin with because the project is still incomplete, and still probably needs months of work. I also have not personally seen the results or verified any of this; it's just something I heard from a very reliable source. However, I can say with 95% certainty that the ECU has been reprogrammed. As soon as I am able, I'll update the entire community because I'm sure a lot of people have been looking forward to this.
well, no offense intended to you and your source, but to coin a phrase, we've heard that before
Personally I don't expect there's as much to gain there as some people think, given TOMs can make changes to the JDM ECU and they don't get much out of being able to do so... 12:1 compression is a much much bigger problem for FI applications than the ECU is... but if whomever it is is actually able to make real changes it would still have some pretty interesting implications, depending on how much they're able to do/access.
Heck, I'd be happy if someone cracked how to reprogram the dash to show real tire pressures in each wheel like even the cheap GM cars do
Believe me Kurtz I know what you're saying about others having stated similar things in the past and I agree wholeheartedly. I'm honestly hoping this is true and as of right now i have no reason to believe it isn't. I won't say any more on the matter until it has happened or hasn't happened.
new guy i would just do spray for thats price and all you may get is 60-90 hp with 125 shot i got close to 95 hp and its $600 with some bit of fuel line custom set up not to hard to do , but you need to update the clutch if its stick if not the auto holds close to almost mid 360hp befor you start having some issue
I know where the source is coming from and I'm pretty sure it will happen soon..just be little more patient
Omg this thread is major blue *****; 2 major cockteases in one thread is more than I can handle
sometimes i wish people wouldnt post until their ish gets worked out.
anyone have any updates on the twin supercharged IS? lead time was supposed to be 35 days, its been 60 days!
