Best Exhaust for 2010 isx50
#32
So all axlebacks will basically be carb certified because they aren't changing anything...or they don't need to be certified because they aren't changing anything. Either way I think I may be leaning towards the Tanabe, nice sound and low drone. Anyone know if the tanabe touring medallion fits on a 2010? I noticed most websites only say 06-09...did they forget to update the years?
#35
Like with most things involving the law, as long as you don't stick out like a sore thumb you should be safe, but if you run into a PMSing popo, there's not much you can do. As long as you keep the decibels under 95, you SHOULD be okay in Cali.
#40
Received 1,064 Likes
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
It doesn't mean it's CARB certified, it just means that it shouldn't be illegal. But again, the law seems to be vague (intentionally so I'm sure).
Originally Posted by DMC.CA.GOV
V C Section 27151 Modification of Exhaust Systems
- Modification of Exhaust Systems
27151. (a) No person shall modify the exhaust system of a motor vehicle in a manner which will amplify or increase the noise emitted by the motor of the vehicle so that the vehicle is not in compliance with the provisions of Section 27150 or exceeds the noise limits established for the type of vehicle in Article 2.5 (commencing with Section 27200). No person shall operate a motor vehicle with an exhaust system so modified.
(b) For the purposes of exhaust systems installed on motor vehicles with a manufacturer's gross vehicle weight rating of less than 6,000 pounds, other than motorcycles, a sound level of 95 dbA or less, when tested in accordance with Society of Automotive Engineers Standard J1169 May 1998, complies with this section. Motor vehicle exhaust systems or parts thereof include, but are not limited to, nonoriginal exhaust equipment.
Amended Sec. 10, Ch. 92, Stats. 2001. Effective January 1, 2002.
V C Section 27150 Adequate Muffler Required
- Adequate Muffler Required
27150. (a) Every motor vehicle subject to registration shall at all times be equipped with an adequate muffler in constant operation and properly maintained to prevent any excessive or unusual noise, and no muffler or exhaust system shall be equipped with a cutout, bypass, or similar device.
(b) Except as provided in Division 16.5 (commencing with Section 38000) with respect to off-highway motor vehicles subject to identification, every passenger vehicle operated off the highways shall at all times be equipped with an adequate muffler in constant operation and properly maintained so as to meet the requirements of Article 2.5 (commencing with Section 27200), and no muffler or exhaust system shall be equipped with a cutout, bypass, or similar device.
(c) The provisions of subdivision (b) shall not be applicable to passenger vehicles being operated off the highways in an organized racing or competitive event conducted under the auspices of a recognized sanctioning body or by permit issued by the local governmental authority having jurisdiction.
Amended Ch. 558, Stats. 1977. Effective January 1, 1978. Supersedes Ch. 579.
nMeOnE
19
08-14-12 04:49 PM
