yup its definitely leaking somewhere! lol @ shop did your install better take a look at it yourself... you could try some color smoke to see where its leak from.
if leaking, it will cause the engine light or check svc on right??? Thanks!
Yes, it will cause the o2 sensors to throw a cel because the air is leaking out before it can read it, most likely throwing a rich condition or an o2 sensor "failure" cel. Get your codes checked, reinstall the midpipe, and if you understand the codes that were thrown, clear your ecu by pulling the fuses.
now "Check VSC" & "Check Engine" on....i need help
same as my friend car, all those light came on after one day installed the midpipe, but his car not sound like that, look like your car sound like broken muffler like
