anyone have info on the acoustic control induction system (acis)?
The ACIS is in the manifold itself (at the rear). I believe it runs off vacuum to make the intake runners longer at high vacuum (light throttle) for more torque and shorter at low vacuum (heavy throttle / WOT) for more HP. I wouldn't mess with it unless I was FI. Then I might remove it all together just because it could be a restriction. If you unhook the vaccum line from the valve at the back of the intake, it should stay open in the WOT mode. You should give it a shot & report back.
