New GTech results in...I still gotta practice :)
Just did 2 runs on my Gtech (my friend borrowed it for the last 3 months). First weather here on Long Island is about 60 degrees and low humidity; very dry. Barely any wind where I am when I was doing these two tests. I used the same strip of road going in the same direction for both runs...a relatively flat, straight road.
I had a 1/2 tank of gas, full spare, my 19" wheels and had the ECT PWR on for both of these runs. I tried the first run with traction control OFF and the second run with traction control ON.
RESULTS:
I STILL to this day do NOT know how to properly launch my car without either losing GOBS of traction or letting off the gas too much...the following results show just how much I let off the gas to try to re-gain traction off the line.
RUN #1 Traction control OFF
60' = 2.37 sec
0-60 mph = 5.835 sec
330' = 6.163 sec
1/8 mile = 9.327 @ 79.82 mph
1000' = 12.026 sec
1/4 mile = 14.318 @ 98.38 mph
The next run I decided to use the handicap of traction control because obviously I still do not know how to properly launch my car without massive traction problems. So now I tried with traction control ON.
Run #2 Traction control ON
60' = 2.217 sec
0-60 mph = 5.460 sec
330' = 6.023 sec
1/8 mile = 9.055 @ 84 mph
1000' = 11.607 sec
1/4 mile = 13.754 @ 105.44 mph
So, from the results my run #1 first 1/8th mile was greatly effected by loss of traction where I had to tak my foot off the gas a re-apply; killing times and performance which in turn effected my 1/4 mile and trap speed. In run #2 I still had a little wheelspin but then traction control kicked in and retarded the accelerator to regain traction (I still had the pedal mashed though). From this my 60' still kinda sucked but it still showed that the car is very capable for a modded NA GS400. BTW, my trap speeds were probably a little inflated because I used a 6" roll-out on my GTech setup.
I estimate that if I would go with a better rear tire (like Michelin PS2 or Toyo T1R's) and went to a 35 series tire instead of my VERY thin sidewalled 30 series along with traction off I BET I could get my 0-60 down to or damn near close to 5 seconds flat and the 1/4 mile down to around 13.4 seconds. We all know that the worst way to launch is by having traction control ON. But in my situation I had no choice and I just wanted to see how the results would compare. Sometimes I think my 3000 stall torque converter is my own worst enemy.![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
Thanks for reading guys. I will do more testing when I get a chance. Now that the winter time is coming I will be throwing on my OEM 16" wheels and I will buy nice sticky rear all seasons for them; then I will do more run also with this setup...it will also be even cooler out by that time.
Nick
RESULTS:
60' = 2.37 sec
330' = 6.163 sec
1000' = 12.026 sec
60' = 2.217 sec
330' = 6.023 sec
1000' = 11.607 sec
Nick
I used a gtech a few years ago.
I have an 02 430, best 0-60 was 5.57 on stock 17's with a heavy system in trunk. Traction control was off.
I dont understand how you got such a good 0-60 with the traction control on, whenever I leave it on and step on it, it bogs badly. My best 0-60 with traction control on was about a full second slower than with it off.
Oh yeah, I have a 2800 stall converter. Thats it.
Well, the heavy system in the trunk probably helped you with traction. I will throw my box back in my trunk as well and do some runs with the traction OFF this time.
I got such a good 0-60 time because I am still pushing more power than what you had on your setup. Point is with proper weight in the rear (and tires) giving me better traction with traction control off should yield closer to 5.0/5.1 0-60 times. Which would make sense.
Also, one day do me a favor and weigh your 17" stock wheels and tires. I am SURE they are EACH 10lbs lighter than my 19" wheels. Eventhough my 19's are 2-pc forged they still weigh 30.5 lbs; with tires the rear wheel/tire combo is a whopping 62 lbs EACH! Smaller, lighter wheels with stickier tires and thicker sidewalls are definitely better for racing IMHO. Larger wheels just look nicer to me. I guess you can't have it all though.
I understand you're making more power than me. what I meant was my traction control kicks in and completely slows me down. I raced my friend in an 04 ls430 with traction control on he destroyed me. With traction control off, i took him by about a car length.
So basically, even if i had 100 more horsepower than you, i dont see how i would get a fast time with my traction control on. Im just wondering if something is wrong with my traction control.
Also, another little piece of information I left out. I also have the 3.76 Supra TT LSD; which EVERYONE knows actually HURTS 0-60 times because NOW my car shifts into 3rd gear at 58.X mph instead of the stock 61.X mph...and my times are still good which makes me happy.
The only reason why I got this rear end is for the limited slip differential. The 3.76 ratio as mentioned previously kills 0-60 times from the stock 3.26 gearing. HOWEVER, it HELPS overall in 1/4 mile performance as it does provide quicker acceleration at any speed. Certain performance points like 0-60 tests unfortunately get effected due to the required extra gear change. IMHO a 3.5X or a 3.6X LSD would be the best for our (V8 Lexus) cars if it existed.
I will post some videos up when I get a chance. I am not sure who else on these forums have the same exact mods as me. Some have I/E/H but no Neo or no high stall TC, some have I/E, Neo and a high stall TC but no headers or 3.76 LSD etc etc. I am not sure if there are others that have most NA mods done like me.
The only other bolt-on mods that I can think of is a VB upgrade in the tranny for faster shifts and perhaps more extensive exhaust work (I only have a Borla rear section - the rest is all stock).
[QUOTE=Rock-a-Lex; I am not sure who else on these forums have the same exact mods as me. Some have I/E/H but no Neo or no high stall TC, some have I/E, Neo and a high stall TC but no headers or 3.76 LSD etc etc. I am not sure if there are others that have most NA mods done like me.
QUOTE]
I have the same set-up as you except 3.76 LSD. I have not dynoed my car yet though. Great numbers, now I'm kinda curious to see what my numbers might be.
QUOTE]
[QUOTE=dsouth;5838959]
nice...yeah, the car really moves right?![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Originally Posted by Rock-a-Lex; I am not sure who else on these forums have the same exact mods as me. Some have I/E/H but no Neo or no high stall TC, some have I/E, Neo and a high stall TC but no headers or 3.76 LSD etc etc. I am not sure if there are others that have most NA mods done like me.
QUOTE
QUOTE
Who knows...oh, don't forget to get the Torque Master spark plugs and use Royal Purple fluids in all. The TM spark plugs are proven to add almost 5whp and people (as well as I) swear by the RP fluids!
My wheels do suck for racing as well though too...
