Thinking Low Boost Turbo
#31
Well, I heard and read that the previous owner(s) were making around 420whp and around 360wtq where they didn't even have headers! I'd be happy with a very mild tune producing say...370-380whp while it is my daily driver. After that I would probably utilize the smaller custom pulley supplied and perhaps beef up the tranny a little. We'll see. All I know is it is going to be SICK!
Pulling up some old threads by Mr Johnson he mentioned that his 0-60 was around 4.5 seconds and that was WITH letting off the gas to allow the tranny to shift (all that power would just make it bounce off the rev limiter). He mentioned on highway pulls not much would hang with it.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
I have some literature on some of SRT stage 1,2 & 3 kits back in the day.
#32
One curiousity I do have is the available space in a GS compared to my LS. The design will be tightly packaged so it will be a bonus if it will also work on a GS.
Again, the main goal is more power but within the limits of the stock block and the transmission. It will be capable of MUCH more power than I will be using.
#33
BTW is there any way possible that your can send me a copy of that literature to my email? Please let me know via PM and I will send you my email addy. This would be greatly appreciated especially if you have installation instructions.
#37
Initially it will probably use a standard electric system with the vacuum system coming later.
#39
Obviously one of the available electric oil pumps, often differential/transmission oil pumps, are the go to way to scavenge. Tilton is one of the most common, not sure but maybe you are thinking Milodon.
My idea combines vacuum evacuation with intermittent electric assist. This has several benefits. No constant pump noise. Pump only used when boost is present for long enough to need scavenging assist. If electric pump fails simply drive off boost until serviced. Quiet. Elegant. Of course successful implementation is dependent on flow demands and will probably be better with the restricted flow of the newer ball bearing turbos.
Probably be a demand for my system once I get it out of the noggin and into physical form.
#40
There are many members running close to 400whp on stock internals and transmissions, why are you targeting such a low gain? I don't really see the point in 320whp, maybe more on the 340-360whp. Either way I'll give you props, but 320whp is just not enough to even consider all the fabrication you'll have to go through. Unless you go remote mount, quick, simple, easy, and on top of all, cheap.
