PPE V8 Headers GS, LS, SC
Old 07-19-11, 03:07 PM
  #496
LALEX1
LALEX1's Avatar
Has anybody actually dynoed their car before and after to see what the actual gains are?
Old 07-19-11, 07:02 PM
  #497
bcsc400
bcsc400's Avatar
Look at post #397
Old 07-19-11, 09:47 PM
  #498
LALEX1
LALEX1's Avatar
Originally Posted by bcsc400
Look at post #397
Thanks. I think I have seen that post. I was actually looking for a back to back dyno with only a headers upgrade.
Old 07-20-11, 08:39 AM
  #499
JBrady
JBrady's Avatar
Originally Posted by spdrcr771
Ok Im gonna try to put you a list together here.
1. PPE Headers = $600
2. 2 Magnaflow High flow shorty cats = $79ea (ebay free shipping)
3. PPE Cat flanges = $40 (shipped)
4. 6 Mandrel 45's = $129 (less shipping)
5. 2 2ft pcs straight pipe @ $4.50 a ft = $18 (less shipping)
6. 3 1ft pcs straight pipe for custom Y Pipe = $14 (less shipping)
7. Fabrication of custom Y Pipe = ??? cost me ($75)
8. Top Speed Mid pipe resonator 2.5" = $50 (shipped)
9. Rear Y Pipe = $69.19 (less shipping)
http://www.mandrelbendingsolutions.c...pes/Categories
10. Total Install = ??? cost me ($300)
Approx grand total = $1453.19
I know for sure there was another $75 in shipping charges. I saved alot on building the Y pipe myself. The $75 was for the welder guy. My exhaust guy is a real good friend & he spent 6hrs fabing mine. Any other person asked him to do what I did & it would be $400-500. LOL Damn kinda scary when I put a pencil to it. Headers cost me $400, so My total cost was, $1328.19.
I had bought a Top Speed 2.5" straight resonator but internally it necked down and had sharp edges so it is not a true 2.5" part. I sent it back. I recommend Magnaflow, Dynomax, Borla or any part that uses a true 2.5" internal design without sharp edges.
Below are pics of the TS 2.5" that I returned.
Look carefully and you can see that at each end the internal pipe size squeezes down to less than 2.15" and the perforated core that is roughly 2.5" is capped at each end by the squeezed down ends (swaged). On the inlet side this is not that big of a deal other than a slight restriction but on the outlet side a sharp "lip" is created that creates more of a restriction by inducing turbulence as well as being physically smaller.
Keep in mind that the a pipe with an Outside Diameter (OD) of 2.5" will have an Inside Diameter (ID) of roughtly 2.37" so that is your ID starting point.
The stock 60mm pipe (2.37" OD) is roughly 2.14" ID (pipe wall thickness for 16 gauge is .065" x 2 = .130" total wall thickness to be deducted from the OD size.
So, a true 16 gauge 2.5" OD tube has an ID size of 2.37".
The factory 60mm OD tube (2.37" = 60mm) is roughly 2.13" ID.
The Top Speed part has the same ID as the stock tube but with less desireable internal aerodynamics.
BTW, the stock resonators on the GS4xx are actually slightly larger inside than the pipes that feed them! Another reason to KEEP the factory parts that work.
Attached Thumbnails PPE V8 Headers GS, LS, SC-924_0160.jpg   PPE V8 Headers GS, LS, SC-924_0163.jpg   PPE V8 Headers GS, LS, SC-924_0166.jpg   PPE V8 Headers GS, LS, SC-924_0167.jpg
Old 07-20-11, 02:01 PM
  #500
vwynn
vwynn's Avatar
dammit.. i left all 6 resonators (yes 6.. i had 2 stock cat backs lol) at the exhaust shop
Old 07-20-11, 03:35 PM
  #501
johngoldsc
johngoldsc's Avatar
20 hp for the 1uz sounds good
Old 07-20-11, 10:09 PM
  #502
HtownGS4
HtownGS4's Avatar
Just installed my PPE headers on my 98 GS400. First put them on with the factory cats, and 2.5" pipes all the way back (and an x-pipe after the cats). Waaaayyyyy too loud! And seemed to not get much power from them. Went back to the shop and had them reinstall the factory resonators. Wow is all I can say. The car sounds much better now, and I can actually feel an increase in power. Especially through a wider portion of the power band. Need to get it on a dyno to see some real #'s. Though I plan on doing a cold air and an ECU that can be tuned (will be installing cams soon after so I need the tuning for sure). Great buy!!
Old 07-21-11, 02:10 PM
  #503
spdrcr771
spdrcr771's Avatar
Sweet, when you say, you had them reinstall the factory resonators, you meen they put the stock Y pipe & everything back on or just the resonators & stock mufflers. Also very interested in what stage & brand of cams you are going with & tuneable ECU. Dyno now so we can see how much tune & performance you get out of the cams & ecu. Lextreme's stage 2 cams are reported to add 31whp to our motors.
Old 07-22-11, 08:01 AM
  #504
bcsc400
bcsc400's Avatar
I used a Vibrant ultra quiet resonator. It's built with a true straight through core. It also eliminates any drone or rasp and is very well made.
http://vibrantperformance.com/catalo...products_id=46
Old 07-22-11, 12:06 PM
  #505
sakataj
sakataj's Avatar
can u run the stage 2's on OEM valves/springs/retainers or just the stage ones (can you even run the stage ones on OEM?) do you happen to know power level of the stage 1's?
http://www.lextreme.com/Lexus-Toyota-cams.html
Old 07-22-11, 02:32 PM
  #506
vwynn
vwynn's Avatar
you getting cams Brian??!?!
Old 07-22-11, 07:35 PM
  #507
spdrcr771
spdrcr771's Avatar
Yes on the OEM valves. Im not sure on the springs part. But then again, if im already there & im "upgrading". Im changing the springs too. Dont know anything about the stage 1's. I heard the stage 2's on a you tube video, & its not like it was lopping like a big block chevy & idling rough. So why even thing about the stage 1's.
Old 09-04-11, 04:32 PM
  #508
sam430
sam430's Avatar
More pictures for your enjoyment.
Nice! would be nice if there were a couple of flex joints to make the install easier.
Old 09-07-11, 01:44 AM
  #509
sam430
sam430's Avatar
Where did you get the 31whp number from?
Old 09-07-11, 12:35 PM
  #510
sakataj
sakataj's Avatar
i kind of gave up on the idea of the cams/springs/retainers as the cost i can put in a ls2/ls3 and make that kind of power i would be making....
im gonna dyno in the next week or two BEFORE my header install on some fresh plugs and then again after the header install....looking forward to some #'s
Quick Reply: PPE V8 Headers GS, LS, SC
