oil change question
hey guys i just purchased a 93 gs300, and im about to do my first oil change. Now i didnt receive the owners manual with the car, could someone tell me what does the manufacturer recommend usin for oil? 10w or 5w? or what would you guys recommend, i was goin to use mobile one super sunthetic. I also just purchased the blitz sus power intake.. anyone out there has it? how satisfied are you with it? thanks guys
I would stick with 5W30 and here's why. A multi-viscosity oil has a base weight of the lower number. Various polymers/additives are then added to the oil to prevent the oil from thinning beyond the upper number in the range. Ideally if we weren't racing a 30W oil would probably be ideal. However to allow us to drive around in the cold you want the lower base weight. Think about it as a polymer that's coiled and as it heats up it elongates. The 5W30 doesn't have to control the elongation as much as a 0W30 would? (Does this make sense?)
Please see this great link for info that better explains it than I.
In any case, I know that many 0W30 oils are starting to appear but until the manufacturers actually test and advise for them I'll pass.
Originally posted by damnboy
Do you recommend to replace the drain plug too?
If so, where can I get it?
Nah! Not unless you've somehow damaged it or the threads.
