VSC/Brake/ABS Lights-Alternatives to Master Cylinder
Old 01-11-11, 03:53 PM
porn-adkt
porn-adkt's Avatar
Originally Posted by jeu510
do you know if you can just replace the abs unit without the master cylinder?
my lights are on and i've pulled the codes and it has a code for rf wheel sensor and abs module.....any fix.....?
Yes you can
why dont you test your Sensor?
Old 01-17-11, 11:54 AM
jeu510
jeu510's Avatar
Originally Posted by ****-adkt
Yes you can
well, even if i replaced the speed sensor, im still gonna have it on due to the module....i'll have to fine one for cheap before i can even fix the speed sensor...
Old 01-17-11, 01:24 PM
porn-adkt
porn-adkt's Avatar
it may be difficult sourcing just the ABS unit itself, your better off going with a complete 01 Master cyl unit.
Old 10-24-13, 10:45 AM
bamaman
bamaman's Avatar
Do these codes go away if the lights and alarm go off? I wouldn't think so but I'm asking anyway. My 2000 gs 300 had this happen this morning. Took it I my mechanic and I asked him to check the sensor because I still had brakes after following the instructions earlier in this thread.
Old 10-24-13, 01:16 PM
porn-adkt
porn-adkt's Avatar
What did you just say or ask????
Old 10-30-13, 04:40 PM
poloSTL
poloSTL's Avatar
Geez this happened to my 2000 GS 300 on monday...
Due to emissions /check engine light ..had 3 sensor codes show up and decided to replace all O2 sensors but unfortunately could not install the last sensor on exhaust pipe due to crack...
went to meineke to weld my exhaust pipe which they did / still waiting to install O2 sensor
BUT went to start car on monday and all hell broke loose with VSC/BRAKE/ABS LIGHTS
and constant sound within car
I hear a clicking sound coming from brake unit like its trying to pump but to no avail...
So wondering what your mechanic found and pray its a sensor issue (too much coincidence this occurred only after sensors being replaced
Thanks guys
Old 11-07-13, 03:28 PM
bamaman
bamaman's Avatar
As of now I have manual brakes, a beeping time that doesn't stop, and no money to get it fixed. I haven't had the codes read yet but I am sure that it will say the ABS or Master Cylinder need to be replaced. In the mean time I just take it easy and pray hat I don't have a wreck
Attached Thumbnails VSC/Brake/ABS Lights-Alternatives to Master Cylinder-image-3599664383.jpg
Old 03-10-14, 08:54 PM
Bigtimmy
Bigtimmy's Avatar
Default lights on and i got these codesco226 co236 co246 co256 c1241 c1249 c1252c 1233 c1223c
change booster with used still have same codes 2001 gs 430
talexus
Suspension and Brakes
55
04-11-23 09:22 PM
ThatGuyJ
08-27-19 05:06 PM
781rolo
12-14-13 01:16 PM
SynicalVip
09-06-12 11:10 PM
Jabberwock
12-25-10 10:40 AM
Quick Reply: VSC/Brake/ABS Lights-Alternatives to Master Cylinder
