HKS350 does it again! Living up to the title..
Old 01-20-11, 09:30 PM
  #136
andrewshu3
andrewshu3's Avatar
so HKS350.. Compared to the ppe header installation, how difficult was the supercharge install? On a scale of 1-10 (10 is most difficult), with the ppe header install being a 6.
Thanks.
Old 01-20-11, 09:44 PM
  #137
01a4man
01a4man's Avatar
Originally Posted by HKS350
The kit will work on any 2GR-FSE motor.
The intercooler piping is made for any GSE21 platform. So I (think????) this is the IS350 and JDM Crown only. But other toyota/lexus cars may used the IS350 frame IDK?
Thanks everyone
HKS350,
Talk to me bud, what all do I need to get this done?? I probably read it earlier, but excitment might be getting the best of me now.
Chris
Old 01-20-11, 11:46 PM
  #138
kbh
kbh's Avatar
Originally Posted by pepos
All the hardware fits but the electronics won't work on our 4GR-FSE engine.
do you have any idea if it will work on the is300 (asia version) 3.0 L 3GR-FE V6? would love to put this setup on my car
Old 01-21-11, 04:41 AM
  #139
GILLEXUS
GILLEXUS's Avatar
^^Kurtz is right, I'd say the most NA gains would be midrange. You might be able to gain alot @ 20-30 from 3k - 5k.
But tuning the HKS is not easy. HKS does not provide the software to the public. You have to be a "HKS pro" tuner.
This is an issue for me b/c I can tune and have alot with past projects. But HKS wants a 30K buy in to become a "Pro dealer".
So the hardware costs will be @ $1200 but a tuning section will run about the same with a HKS Pro tuner. So you'll have $2400 in just a n/a tune.
Are you going to try and tune it from the pre-tune settings?
Old 01-21-11, 09:57 AM
  #140
D350
D350's Avatar
would the hks F con work on the LMS kit??
thanks
Old 01-21-11, 02:40 PM
  #141
HKS350
HKS350's Avatar
Thanks.
Hmmm,
PPE = 6
HKS S/C = 8
Motor Swap and build = 10
Its an 8 only because there is sooo much to do. Wiring, wire tuck on the motor, bumper removal, S/C install, F-con, cutting a 1" hole in the firewall for the F-con wiring hardness, tons more!!!!!!!!!!!!TONS.
Old 01-21-11, 02:44 PM
  #142
HKS350
HKS350's Avatar
If I can ever get the paperwork on what the F-Con "pretune" setting are.
100% Fail at this moment.
Old 01-21-11, 06:56 PM
  #143
06isDriver
06isDriver's Avatar
Hmmm,
PPE = 6
HKS S/C = 8
SOrry you had to mar your lexus body but ya know, I found a way to get an entire 1/2" wiring harness, a 5/8" hose and a 1/2" hose through a small area from the radiator support to the intake area by removing a small piece of plastic from the left side of the radiator shroud and weaving the wire loom up and under the passenger headlight.
There doesnt seem to be any interference with the HID ballasts either.
So for anyone else that attempts something like this you may not have to drill through your car!
Dude, keep up the work. Does the pre-tune seem to be adequate? Would you consider taking it to a pro tuner for some refinements?
Old 01-22-11, 06:14 AM
  #144
HKS350
HKS350's Avatar
The HKS F-con has a base map that has 64 different settings that can be adjusted. The adjustments can be made via 8 dip switch combinations so a total of 64 possable tunes. All these do is change the base maps around. The HKS F-con monitors the engine data (rpm, timing, fuel% etc...) via the OBD2 port. When its plugged into the OBD2 port its in full time learn mode. When I like the tune I just unplug the F-con from the OBD2 and it will run that map.
The issue I'm having is I'd like to change the base mapping to speed up the tuning process but the cars tune is getting better the more I drive. So I'll most likely wait and see how the F-con does on its own. HKS pro dealer WILL NOT give me any info on the dip switches. This is what they change when you pay them to tune so its kinda there bread and butter to keep it to themselves.
As for the wiring going through the firewall. You have to get a harness about the size of your wrist/forearm into the cabin of the IS. So making your own hole is the only option. The HKS instructions show you where to do so and its very clean OEM'ish.
Old 01-22-11, 07:03 AM
  #145
laobo979
laobo979's Avatar
Any video clips yet?
Old 01-22-11, 07:27 AM
  #146
HKS350
HKS350's Avatar
Kinda, I went to Walgreens and recorded it idling. You can hear the S/C pretty good. But its really crapy video.
I'm going Sunday to do some video footage. But for now here:
http://www.youtube.com/watch?v=dB8-7mxfkFE
Old 01-22-11, 10:32 AM
  #147
cholmes1
cholmes1's Avatar
Nice video. Thanks for the under hood shots. Is that a boost gauge in your vent? Looking forward to a more complete video tomorrow.
Old 01-22-11, 10:58 AM
  #148
D350
D350's Avatar
so do you know if the hks f con works with the LMS kit too?
Old 01-22-11, 05:46 PM
  #149
laobo979
laobo979's Avatar
Nice clip let see one while rolling
Old 01-22-11, 10:47 PM
  #150
IS25Heaven
IS25Heaven's Avatar
Did you get rid of your ce28s?
Quick Reply: HKS350 does it again! Living up to the title..
