K&N cold air intake VS JOEZ pipe with HKS filter
Hi everyone! I wanna ask about the K&N air intake and the JOEZ pipe with HKS filter for my is250. Which one is better? Which one gain more HP?
Royale with cheese
joe z will give you gains in power, but no loud intake. doesn't matter what filter you use. paper filtrates the best and there's no difference in power between filters. i think caymandive actually lost power with a blitz filter.
k&n will probably result in a loss of power but will be loud if you're only into noise.
if you go with a short ram intake. i say go with one that uses a dry element and not oiled.
(some Joe Z owners have gotten the same result noise-wise by just drilling a similar hole in the stock lower airbox)
Everyone here is a biased Joe z nutt swinger, they don't have proof of what they know but dynos from Joe z itself, no independent tests
That appears to be what he's saying but he has no idea what he's talking about...
But folks have done independent dynos of the Joe Z, which he'd know if he'd taken the time he's been using to spout off in ignorance and just run a quick search.
To cite one example (from a well known member)
https://www.clublexus.com/forums/per...ly-tested.html
Gained Peak numbers of 5.23hp and 5.26 peak ft/lbs of torque
Received 1,063 Likes
WoW… LoL
ALL of my R&D Dyno's on the IS250 & IS350 from 2006 were indeed Independently Dyno Tested & Proven by SP Engineering here in Southern California...
And that's a fact "jaxxx"..
Best Regards,
Joe Z
JasonChang
Performance
12
05-30-12 10:07 AM
