Mobile 1 ATF
Mobile 1 ATF
Just an FYI Mobil 1 users...
So I went to serveral autopart stores in my area today and found no Mobile 1 ATF...did some research and this is what I came up with...
From ExxonMobil:
"Mobil 1 Synthetic ATF has not been recalled. It is, however, temporarily
unavailable for sale in the state of California. We can assure you that
there are no performance or safety concerns with Mobil 1 Synthetic ATF.
ExxonMobil stands behind this product. Thank you for your interest and
loyalty."
There was a chemical in the ATF that is not legal for sale in CA.
From ExxonMobil:
loyalty."
That being said, T-IV is ancient in fluid technology, and at this day and time, not really that "special" anymore. There have been so many improvements in synthetic motor oils and additive packages that no one questions, butit follows that similar improvements have trickled into ATF lubricants. Note that even Toyota has changed over to WS fluid acknowledging the advancements in lubrication.
What T-IV does have on a positive side is that it's cheap.
I personally was thinking about going with MaxLife ATF which is full synthetic and meets specs for T-IV *AND WS* (whereas mobil1 is T-IV only) and easy to obtain at parts stores rather then dealers. It costs $5-6/quart and sometimes cheaper when on sale. Meanwhile, Mobil1 or Amsoil you're looking at $7-9 and have to deal with MLM with amsoil.
However, my order at parts.com that I thought was cancelled ended up actually going through, so I have a case of T-IV on it's way to work through for 2 Lexii. At T-IV prices though, I'll just do an ATF d/f every oil change.
It is the same strategy of dino/synthetic for motor oil. For the same cost, you could just change out your motor oil 2x with dino, or 1x with synthetic, but you will also have to change more frequently.
With completely fresh ATF, will your tranny perhaps be slightly smoother with synthetic? Maybe, but it also depends just how sensitive you are to detect minute changes with your car and if that justifies the extra price.
There have been documented cases where people use something different than Toyota Type IV and their tranny's have failed prematurely. Do the research and you'll find out that toyota transmissions are VERY temperamental. So why not just use something that's designed for toyota's? There's no improvement by using other synthetic fluids.
Regardless, there's also plenty of cases of people using Type IV, and the fluid has burned up causing their tranny to fail too (granted some are due to customer neglect, but also when changed on Toyota schedule). On BITOG, plenty of people are unhappy with the quick wear of Type IV and is documented with used oil analysis.
Whatever logic you use for your choice of engine oils applies to the tranny too-specifically for an older spec mineral-based fluid.
It's just that i've read a few stories about people using other ATF then Type IV and running into problems. I just don't see a reason why NOT to use it.
Oh no. Don't get me wrong! I use Mobil 1 fluids everywhere else except for the tranny. Tranny fluid and coolant are the only two things i use OEM on. Everything else is Mobil 1. Oil, oil filter, diff fluid etc...
I did buy Mobil 1 Motor oil + filter & Mobil 1 diff gear oil BTW.
Toyota T-IV is indeed old tech. It's nothing special really. It's basically Dexron fluid with friction modifier to give you that soft engagement. The only reason why I still use T-IV is because it's the cheapest out of all the ATF available for me. $3.50/bottle is a good deal considering most other fluids I've found at $5-6/bottle.
Do or did you notice any changes in normal/accelerated upshifts or tranny downshifts while WOT?
How often do you guys on average change tranny fluid out, I mean the factory recommended service intervals end at around 150k mile correct. I dont know I dont have an owners manual. Also I aggree with the t-iv fluid just in the fact that just as t-iv is old technology so are our trannies they where made in the time of t-iv and are still spec'd for it unless you rebuilt your tranny and upgraded to todays specs.
