My GS430 Wont Start!!!!PLEASE HELP!!!!
I bought a new computer for my car because the one that came with my car had a burnt circuit that i thought was the problem for it not starting. The new computer i bought came with the chip for the key also. I replaced the computer but its still not starting. Do i have to get it flashed for it to recognize my car? and if i get it flashed and it still doesn't work, what could be the problem?
Thats exactly what its doing. I turn the key it feels like its going to start but it doesnt. Im having the ecu flashed today. Hopefully it works out but if it doesnt i will be back to see what the next step could be.
Thanks for the advice bro!
If it still doesnt start check all your power in and out of the ignition area. First make sure the main power wire to the starter is intact and secured with a constant12v going to it. Then check your starter selinoid activation wire, usually a much smaller wire that sends a 12v signal to the starter when the key is in start position. If some how you are getting that 12v signal there to the starter and its not budging. Then its most likely a faulty starter. If however you are missing that 12v signal when the key is in the start position then you infact have a sercurity trouble code not allowing the car to start or the starter relay maybe bad or ECU may not be ready for the car ie (flashed yet). Keep us up to date. Also just for my FYI is everything else in the car working all accesories/radio/lights anything else that turns on with the ignition. Does the fule pump get its 3-5sec 12v power when you first turn the key on etc. Where in florida are you
