ZEX EFI Universal Wet Kit Nitrous ?
How much did the kit cost? Will you be getting any accessories? Purge, bottle heater, pressure gauge, etc.
Was interested few months ago but I got a quote for $2500 including parts and labor..![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
Btw, isn't Nitrous Express 100HP shot = ~100WHP? That's what I heard.
The only saftey features that are a must are a WOT trigger, 2000 rpm window switch, and a fuel PSI saftey switch.
Google for the prices and brands, there is tons of options out there. Zex has a built in WOT trigger @ 4.5 volts input.
You can safely run a custom 80HP shot which gave me 50+ WHEEL HP.
The AFR stayed safe. The factory fuel pump can't keep up with demand with any bigger shots.
Kyb: That is a excellent price on the Zex kit. The nitrous kit itself is pretty cheap. However, the labor and the accessories is going to kill you. I wish we can just buy the kit and be done with it.
HKS: A 80 shot only yields 50WHP? From my understanding, the Nitrous Express displayed HP is the actual WHP. So if I purchase a 75HP shot = ~70WHP.
Can a 100 shot be run safely on the 350?
Fuel psi switch http://compare.ebay.com/like/2005983...=sbar&_lwgsi=y
Window switch RPM based: http://www.google.com/products/catal...ed=0CE0Q8wIwAg#
Motor = $3500
Extra saftey = $150
HKS , saftey is my first priority bc it is my DD, so you think i will be able to safely run a 50 without worrying about too much. Yes no issues at all, if installed correctly I wont be shooting it very often.. Yes you will, its like crack
Also, what RPM range is your window switch set at?..
You don't "need it" but I ran the extra saftey.
Motor = $3500
Extra saftey = $150
100 shot wet? NO not enough fuel. Proven on the dyno. You may be able to install a IS-F fuel pump but honestly IDK if there is a diff between the fuel pumps in a 350 and an ISF ??????
Motor = $3500
Extra saftey = $150
Is there any reason why you chose Zex over NOS,NX? Really leaning towards a NX kit since their shot are rated at the WHP. Just curious to know if the car can handle a 75 shot (~70WHP). Which is basically ~90HP to the crank for Zex kits.
Have anyone heard of the "blackout" nitrous system from Zex?
http://www.zex.com/zx/nitrous-system...wet-black.html
I read some mixed reviews on the Purge kit. It isn't absolutely necessary but it is just good to have.
• Includes jets for adding 55-75 HP
• Active Fuel Control™ monitors bottle pressure & adds or subtracts enrichment fuel for maximum engine safety & power
• Engineered for stock type engines but will also work on highly modified engines
