JDM 2jzgte vvti swap GS300
Old 02-11-12, 06:40 PM
  #76
99 GS3
99 GS3's Avatar
Originally Posted by 2jslick
hey 99 gs3 thanks a lot man.... i been posting on other threads trying to find answers but so far ur the first to help me out so i appreciate that... ok one more question. so code 42 is the speed sensor now how do i fix it? i've read that theres a wire behind my dash cluster i have to splice or sauder but im not sure. can u point me in the right direction as to how to fix the vss? its the only thing wrong with my car...
The wire at speedo is an SC thing..
Whats the details on your install? You have an 01, was an it an early or late year 01?
-Did your 01 have the Aristo/98-00 GS/Early 01 GS ecu harness or the Newest Style Late 01+ ecu harness?
-Are you using the GS or Aristo Engine ECU?
-Did you get the Aristo MAF with the swap?
-Are you using the GS or Aristo ABS/VSC/TRAC ECU??
Assuming you are using all ARISTO everything, you should check the VSS sensors for resistance.
If the sensors seem ok, and if you in fact had a New Style Late 01+ harness and had to cut/solder/repin/modify the harness wiring then I would check everything that was done there next.
This info is in another thread I posted it in, but I'll just post it here again. There are two VSS sensors on the Aristo trans, no 1 should be the front one, but you might as well pull them both and test them to see if the readings on both are in a similar range.
Old 02-12-12, 08:32 PM
  #77
2jslick
2jslick's Avatar
99 gs300 thanks for the info Ok so my gs300 is an early 01 not a late 01 I search a thread on hot To Tell if u have an early or late by looking at ur ecu so that's how I know... with that said my swap came off a 99 aristo all I did when I swapped the motor into my gs is run the tac wire in the igniter like I read on here and I ordered a Brand new maf from rhdjapan.com since my swap didn't come with one.... I am using the aristo ecu and the aristo trac abs and vsc computer as Well... so I will check the resistance on the vss and make sure its at 0.64 right? if I have to replace them do I need the jdm sensors or will the u.s. spec work? Is this all that could be wrong? I shall look under the car there is a possibility I migh of damaged one since I did the swap by myself...it sure was a b***h putting it in alone. Thanks again
Old 02-20-12, 02:25 PM
  #78
AristoKing
AristoKing's Avatar
I love the blue on your GS... the simple swap looks good, nice sleeper you have there.
Old 02-28-12, 09:09 PM
  #79
GS300LUV
GS300LUV's Avatar
Well Im ordering my swap in the morning from Japan Direct in Canada in the morning!!!! So stoked. Ill call and ask for Moe and tell them you said to tell them Fred sent me! Thank you for all the helpful info and all the sweet pics. Hows she driving now? Any updates? You still on the stock twins?
Old 03-13-12, 09:01 AM
  #80
Mr.Gs_GTE
Mr.Gs_GTE's Avatar
Damn, My engine gets here next week and my swap is in an 03 gs300. Word on the streets is that it's gonna be a b****. All I can say right now is thanks to all you guys subscribed to this thread. Y'all informations are very helpful and I wish I had done this swap b4 to help with some inputs only my previous swap was on a Jzs147 gs300 which is a bit different from this. But when I get started and come across something that I can possibly help with I'll be posting. If anybody have some pointers please feel free to drop in. One question tho, guys that didn't get you engines with the drive shaft, where did you order one from? eBay ain't got any. There's 2 on there both of which are for the 93-97 aristo. Would the first haft of those work? I'm not too clear as the s147 aristo didn't come with the vvti gte but they r all from Japan so the you're might match up not sure. Any inputs??
Old 03-19-12, 08:05 AM
  #81
2jslick
2jslick's Avatar
I didnt receive my swap with a drive shaft so i use the front shaft off a 99/00 ls430 and i took it to a drive shaft shop and had it cut down to my gs300 size it was a little tight to get in so i suggest cutting it down maybe a half inch to an inch shorter than stock to allow u to install it a bit more easier
Old 03-19-12, 08:27 AM
  #82
Mr.Gs_GTE
Mr.Gs_GTE's Avatar
Does anybody have an extra vvti ecu without the immobilizer? Please get at me!
Old 03-19-12, 09:25 AM
  #83
88supramki
88supramki's Avatar
Check eBay
The ECU Model you want is: 89661-3A470, that one does not have the immobilizer
Old 03-19-12, 11:08 AM
  #84
Mr.Gs_GTE
Mr.Gs_GTE's Avatar
Thanks man, thing is I have and there's one on there. This guy wants 550.00 for the damn thing.
Old 03-19-12, 11:16 AM
  #85
Mr.Gs_GTE
Mr.Gs_GTE's Avatar
Actually I'll take that back. Thanks for the part number, I found a cheaper one!
Old 03-19-12, 12:40 PM
  #86
88supramki
88supramki's Avatar
That's good. It's not going to be super easy to find one, but I'd look on ebay and hit up just about every JDM importer I could find. Chances are they might sell you one
Old 03-19-12, 01:57 PM
  #87
99 GS3
99 GS3's Avatar
A friend of mine has one he want's $300 shipped for. If you end having any interest let me know, I can give his contact info and you can work it out with him.
Old 03-20-12, 05:47 PM
  #88
Mr.Gs_GTE
Mr.Gs_GTE's Avatar
Thanks man, I found one already. Trac/abs/vsc ecu is next on my list. Gotta track one of those down.
Old 03-20-12, 05:51 PM
  #89
Mr.Gs_GTE
Mr.Gs_GTE's Avatar
Thanks man, I found one already. Trac/abs/vsc ecu is next up. I Didn't think I would need one but I do.
Old 03-20-12, 07:06 PM
  #90
99 GS3
99 GS3's Avatar
you got pm.
Quick Reply: JDM 2jzgte vvti swap GS300
