TBKO Turbo
#31
Originally posted by Sentinel
Well we all drive is300s not supras or sc300 or gs300 so for me at least your time with is300s is all that counts lots of shops have experience tuning supras.
ISDude, hmmm transmission hmmmm, not sure.
#33
Hey Wxman,
I agree with your point about a shop that tunes Supras should be familiar with is300 and although the engine codes for is300 and Supra N/A are the same, it's still quite different. The difference = VVTi. Big diff. there in tuning methods. We went over this many times on the is300 forum. Just FYI. Hey what's up Sentinel.
#34
Originally posted by isman
Hey Wxman,
Hey Wxman,
#35
Hey Wxman,
Take it easy fellow .net member and fellow is owner. No one is taking away anything from PHR. That has been recognized period. Just pointing out the fact Supra N/A engine and IS300 engine is not totally same. That's it. Geeeshh
![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
#36
whoa the battle rages on/.... both points are made.. and made well... see the thing is yes the VVTI is a difference.. but a seen difference that some Supra tuners have had to battle prior... hence the 1998 NA supra has a VVTI GE motor in it jsut like the IS300 one... the biggest difference between the two is the ECU.. OBD 1 OBD 2 ver whatever I think it is 2 or 3 that makes it harder to tune slightly.. and also the multilink is a tougher task to work with...
if it is VVTI you are worrying about well to be honest that is the least of your worries you can always disable it if you know how too.. and then move on from there... the basic power tuning of the IS GE motor with a Turbo and GTE motor is the same... only very small humps you need to get over.. but once you get it down.. like Lance well there is no turning back...
#37
I can understand ppls skepticism with kits and shops right now cept for lance jsut cause of the amount of cars he has done and the lack of problems he has had.... I dont blame them... beleive me... I have been thru NITEMARES.. and most everyone knows them... hence TICALIS has been thru some headaches as well.. we jsut move forward and keep pushin for more out of our cars...
#38
#39
Originally posted by Turbo'd_Wxman
Thanks Brian, when I say things no one seems to listen though.
We also know that everyone is starting basically from scratch on the electronics package w/ the IS but once they gets through that it's just the same old GE and there's no surprises. But they have to pass those hurdles first. there's a ton of tuners out there working on IS's that aren't on these boards. That proves this.
We all find the tuner that has the kit or install we like, handover our keys and a wad of money and get horsepower. Some tuners fit some peoples needs better than others. When you are completely satisfied that means you picked the right tuner.
#40
everyone is so touchy now a days. All i was saying is that the is300 electronic are more complex then that of a supra. THAT IS ALL. I have nothing against any tuners (quite the opposite the more tuners the better). But Toyomoto is the only one with alot of times on there cars.
That being said when I go turbo I doubt Ill be going with toyomoto because of distance and $$$. But if i wanted a proven solution it be toyomoto.
Hey isman I still want those hood pins.
#41
Hey Sentinel,
Sorry buddy, the hood pin is on my car now
. I had to put them on cause don't wanna mess things up especially after boost (just to be safe). Ask Rob at Fizz. Think they're like $40. or something.
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
#42
noo!!!!!!!!!! ok
Hey Sentinel,
Hey Sentinel,
#43
How much does a full install on a quality turbo cost? And what are the risks? I mean if you have a ton of miles on the car is it not a good idea? How many miles should you have?
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
#44
Now for the miles thing, I recently saw a Supra with 100,000 miles on the original stock engine and a single turbo conversion dyno at 780 rwhp. So, if you have taken care of a car, I wouldn't worry. SC300Turbo has over 100,000 miles too I think.
#45
1k....nope....
Installation is $2,000 and it takes 2 weeks or less.
Thanks,
Ray
Powerhouse Racing, Inc.
Sales Department
(817) 529-4800
(817) 529-4801 Fax
www.PowerHouseRacing.com
Thanks,
Ray
Sales Department
(817) 529-4800
(817) 529-4801 Fax
