Engine Swap
Old 03-17-11, 11:18 AM
wpagan13
wpagan13's Avatar
Default Engine Swap
Hi I am new to this forum I have a IS 300 (2002) 2JZ-GE automatic basically what I'm trying to do is switch to a manual transmission automatic is just boring but people keep telling me the it would be easier just to replace the whole engine I hear a lot of chatter on this forum about the 2JZGTE Supra so my question is what’s the best engine choice for my IS 300? Keep in mind I definitely going manual and this is my every day car some feedback will help thank you.
Old 03-18-11, 09:47 PM
Billiam824
Billiam824's Avatar
Here is some great info
http://my.is/forums/f114/new-forced-...inside-346858/
Helped me a lot
Old 03-21-11, 11:22 AM
wpagan13
wpagan13's Avatar
thanx man really good Info still a little not sure about which engine but what you post send me in the right direction thank you
Old 05-17-11, 05:21 PM
iii
iii's Avatar
it's all about preference..what do u want to do with the car?
Old 05-31-11, 12:59 PM
ISNINE
ISNINE's Avatar
And how much you want to spend.
If you don't want to produce big numbers I would just keep your engine an get a used IS manual tranny.
Old 06-03-11, 12:51 AM
pikachukia
pikachukia's Avatar
IIRC the is300 m/t is the same as the cressida's (w55 m/t?)
someone confirm this though
Old 06-03-11, 06:54 AM
baadhabit
baadhabit's Avatar
google is your friend
http://en.wikipedia.org/wiki/Toyota_W_transmission
W55
This was the first of the aluminum-shelled W-series transmissions.
The W55 appears to be a base reference point for gear ratios that Toyota used to fine tune later models of the W-series.
Ratios:
First Gear: 3.566:1
Second Gear: 2.056:1
Third Gear: 1.384:1
Fourth Gear: 1.00:1
Fifth Gear: 0.85:1
Reverse: -4.091:1
Applications:
1982-1983 Toyota Carina
1981-1985 Toyota Celica
1983 Toyota Corona
1986 Toyota Soarer
1986 Toyota Crown
1983 Toyota Chaser
1984-1988 Toyota Pickup 2WD with 22RE(EFI) engine
2002-2005 Lexus IS300 (US Market only)
Old 06-19-11, 06:14 AM
jazilla
jazilla's Avatar
From what I've read, it's been said the w55 wont hold very much power reliably. But I wouldn't know from personal experience.
Cavery34
10-19-15 03:47 PM
Deception
10-24-06 07:08 AM
HQuakers
Performance & Maintenance
06-23-04 11:13 AM
soneedaze
04-22-03 11:46 PM
Quick Reply: Engine Swap
