M2 Axle-back
#526
Most likely. These replica exhausts all generally come from the same place, even Megan uses the same reverse engineering to make their stuff.
From the looks of it though, the welds may not be as good as the M2. Haven't seen it in person to really give a judgement though.
#529
Thanks! As of now no other exhaust mods but I do plan on picking up an Invidia Midpipe later on after I get coilovers. I've been lurking around this thread for awhile now and waited for a slight price drop and I suppose a $20 drop swayed me to pick one up. I also plan on doing a resonator delete, but i'll see after I recieve the M2 next week. Hoping the m2 + my K&N shortram is a good duo. I'll keep updating once it's delivered.
#531
on ebay, a lot of it says it won't fit on AWD? is this true because I've seen other members with AWD have this exhaust. Unless you need to buy a certain one. But from what I remember all exhaust for the 2IS should fit the same regardless if its RWD or AWD. Can someone confirm this? lol
#532
https://www.clublexus.com/forums/per...awd-is250.html
#533
Axleback exhausts fit all models. Difference between RWD and AWD is in the midpipe. You're good to buy one
#534
Hey guys I just ordered the M2 Axleback from boneheadperformance on ebay last week and it's coming in tomorrow...how much do you think a local shop would/should charge to have it installed?
#537
Thanks for the input guys, I installed it today but the driver side hangs a lot lower than the passenger side which seems to be higher than its supposed to be...how do i fix this?
