View Poll Results: Airfilter Type You Use in your GS400/430
K&N Drop in Air Filter (not cone)
145
47.23%
TRD Drop in Air Filter
40
13.03%
Amsoil Drop in Air Filter
0.65%
Some Cone filter with an Intake
47
15.31%
OEM Filter (Lexus, Fram, etc.)
73
23.78%
Voters: 307. You may not vote on this poll
TRD or K&N Air Filter or ???
Old 03-02-05, 11:40 AM
  #61
Mrbig
Mrbig's Avatar
Default intakes
So what you guys are saying is if you put in a drop in filter get a Kn and ??? do you reset the ecu and how do you do that ??? If you go with a full intake get the srt with the new ecu ( this will affect ur warranty correct) ??? Please let me know, thanks......
Old 03-02-05, 12:11 PM
  #62
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,310 Likes on 1,409 Posts
MrBig do you have a third generation 2006 GS or a second gen 2005?
Also - have you tried our search feature? Every question you've asked here has been covered many times and you can get instant answers with no waiting
Old 03-03-05, 08:23 AM
  #63
Mrbig
Mrbig's Avatar
Default Intake
Thanks, sorry i have a second gen 05, but i will try and do what you said see what i find.......
Old 03-03-05, 09:18 AM
  #64
Mrbig
Mrbig's Avatar
Default Kn
Whats the part number for it the only one i found was on martel brothers but they only have up to 04 not for an 05 i assume they are the same thou ??? Part number they ( #KNE33-2220 ) is that right please let me know.........
Old 03-03-05, 10:06 AM
  #65
jonathancl
jonathancl's Avatar
Default K&N in the mail
Look what just arrived:
So, if I install this and remove the rubber stopper under the accelerator, that's like +40hp, right??
Old 03-03-05, 02:19 PM
  #66
Mrbig
Mrbig's Avatar
Default Drop In
When installing a drop in filter does the ecu need to be reset ??? How do you reset it ???
Old 03-06-05, 09:45 AM
  #67
DaveGS4
Forum Administrator
DaveGS4's Avatar
Mr Big,
Probably don't need to, but you can just in case and it won't hurt anything
You can reset it by
a.) removing the battery cable for a few minutes
b.) pulling the ECU fuse in your fuse box located (in the 4) in the engine compartment near the windshield, passenger side
Photo courtsey bananags
And a thread with a decent explanation click here
If you flip open your fuse box and look at the inside of the lid, it will have a map to tell you what each fuse does.
If you have a non-nav car, you will lose your radio settings and your personalized seat / mirror preferences.
Old 03-16-05, 05:51 AM
  #68
DASHOCKER
DASHOCKER's Avatar
I have a k&n drop in in my 98 gs stock with 17's. how much of a H.P gain am i getting with the k&n drop in? anyone dyno there car to see?
Old 04-08-05, 09:34 AM
  #69
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
I'm also planning the drop in K@N filter... My concern is the reseting of the ECU... Is it the Neg. terminal on the battery? thanks tmf
Old 04-08-05, 10:28 AM
  #70
rheiy
rheiy's Avatar
To be quite honest, I did not feel any gain what so ever in performance when I switched out the oem and put in the K&N. I believe its nothing more than marketing hype on K&N's part. The only advantage to the K&N is that you can clean it and re-use it. No more no less. BTW, my gas milage was the same with oem vs K&N.
Old 10-08-07, 12:56 AM
  #71
whiterice
whiterice's Avatar
has anyone tried the new HKS hybride filter?? iono
Old 12-24-07, 08:09 PM
  #72
GSkid
GSkid's Avatar
i have a K&N and its awesome, when you take it out to clean it, you can see how much crap it traps!
Old 12-25-07, 12:36 AM
  #73
4ntvings
4ntvings's Avatar
i just got the k&n drop in for its warranty.
be moderate on the oiling, you can clean/reuse it. i doubt there's really any hp gain, but it breathes more air (maybe not that much more than oem though); which should be good for the car, right?
Old 03-16-08, 09:09 AM
  #74
RX729
RX729's Avatar
K&N's last longer...
Old 07-24-08, 03:03 PM
  #75
zacky
zacky's Avatar
Default Airflow problems on GS 430. Lag, Hesitation
I have installed a k&n air filter in my 2001 gs430. 1 month later i started experiencing problems. When I push the gas under low RPM, the car stalls and RPMS drop, then I'll push the gas again harder, and the car would drive. problem got worse. When my mechanic checked it out, the computer showed that it was the maf. He remove the K&N filter, and it looked like playdough. Very dirty and greasy. I never had that problem before. The ECU light never went on.
I see here that many people complain about the same problem with their GS430S. I dont know what the problem is exactly. Can it be the MAF? or Cleaning the fuel injectors? or the TPS? or throttle body?
Any feedback would help a lot. Thank You.
j0mama
GX - 2nd Gen (2010-2023)
12-31-15 05:42 PM
kuroi_tuki
04-07-09 12:18 PM
lozzmo
09-06-06 07:05 AM
mcgong
Performance
11-21-02 07:57 PM
Quick Reply: TRD or K&N Air Filter or ???
