replacing aftermarket exhaust gaskets...
Hey guys,
I pulled my exhaust off this weekend to throw some headers. As I took my aftermarket exhaust off, the gaskets crumbled in my hands. What should I do about this? Can I order new ones? or should I just make my own?
If make my own, how should I go about it?
Thanks
Thanks
Hey guys,
Thanks
Thanks
I looked at this before online but never went to check it out at a local store.
http://www.amazon.com/Mr-Gasket-5960...ata/B000BWAPHA
http://catalog.remflex.com/category_s/104.htm
http://catalog.remflex.com/category_s/24.htm
I need something like this, but not sure if it'll fit.
http://store.prestoliteperformance.c...asket-2-5.html
Hole Diameter: 2.5", Bolt Circle: 3.5", Bolt Hole: 3/8" 3 bolt hole. Multi-Layered Steel (MLS) header collector gaskets are designed for extreme cylinder pressure produced by high horsepower-high compression turbo-charged, supercharged & nitrous oxide engines. Manufactured from three stainless steel layers, resists corrosion, will not burn through or push out & maintains maximum fastener torque retention. Stress formed inner and outer layer embossments act like springs that rebound under exhaust flange clamp load. Applications: Dynomax, Flowtech, Hedman, Hooker Headers, etc..
I got big sheet of exhaust gasket material at AutoZone for like $12 a few monthjs ago when I was installing my Greddy Exhaust and just made/cut out new gaskets myself. Time consuming but worth it.
