Where to get O-Ring Gasket?
Just purchased a used Lexus exhaust, previous user used 'epoxy' to seal both of the mid-pipe flanged ends and I did not see any O-Ring gasket. Any one know the part number for the O-Ring? Or where can I get it? I'm in CANADA!
Also about the M10 bolts and M10 nuts, can I use any kind that I can find at a local hardware store? Or are these bolts heat treated, high strength or whatever?
THANKS!
THANKS!
Sewell sells them:
http://is.sewellparts.com/oem-catalo...S350-2006.html
Kind of pricey though for a gasket - $28.72 with CL discount. They also sell the bolts and nuts.
Received 1,064 Likes
You need the the two gaskets that connect the F-Sport / Lexus HKS axle piping sections seen here:
I would call up Sewell, and see if they can put together a "Service Parts Kit" for the F-Sport Exhaust...
That way you can get all new (properly designed) F-Sport hardware and gaskets for your install.
Do it once & do it right..
Regards,
Joe Z
Sewell sells them:
Ok so you don't mean the large donut gasket that connects the mid-pipe resonator to the rear axle exhaust flange ??
Regards,
Joe Z
Regards,
Joe Z
Thanks!
vkriss
03-15-19 10:30 AM
qewani1
01-25-10 04:01 PM
