Transmission Cooler Threaded Fitting Sizes to use -AN Braided Lines
#33
just the ones we texted about the other day vince....
all the lines were assembled but are being sent back to the shop to be re-assembled and have a few lines recut. will hopefully get to this coming week or next week at the latest. gotta pick up my suspension parts from the powdercoater this week also so i dunno which one i will get to first
#34
Just wondering, how come all the AN fittings? The cooler lines are all fairly low pressure, like under 20psi or so. The normal push on hose with a clamp works just fine. I was running my twin tranmission cooler setup with just the rubber hoses clamped on. Or are you just doing it for looks? lol
#35
jk. it looks nice none the less
#36
here's a update vince
its coming..... all fittings assembled with teflon tape, all lines now put together, 2 cases (24 quarts) of tranny fluid has arrived. getting on my buddies rack next week and getting these all installed
![Name: a45bea86.jpg
Size: 152.3 KB](https://www.clublexus.com/forums/attachments/performance/461233d1501791993-transmission-cooler-threaded-fitting-sizes-to-use-an-braided-lines-a45bea86.jpg)
mainly just for looks jeff ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
shup up vince lol
shup up vince lol
#37
alright so i started working on this but only got so far as i couldn't remove the OEM tranny fittings from the tranny while it's installed....well i didn't have the correct tool to do this. any tips/thoughts/suggested tools to remove these while the tranny is still installed?
#38
Is it possible to take a pic up under the car? I don't recall the clearance between the trans and the tunnel. But if you unscrew the fittings off that hold on the hard line and bend it out of the way I can't picture why you can turn the other fittings out?
#41
last update was in here....and it was a complete listing of my parts i used (i went overboard so most these werent needed)
https://www.clublexus.com/forums/per...r-the-2gs.html
in this thread there are pics galore
as for a update. still havent been able to remove the OEM fittings while its in the air due to the very small gap to work in. i got some open wrenches i might try and then if that doesnt work,i will have to drop the tranny mount and angle it a bit when i do my engine mounts
