2JZGTE swap has begun
SlvrGS300 - any info on what pins I need to switch around? I cant get my shift lock to release and any info you can help me with would be appreciated!
When I did my swap, I had to swap the pins in the grey plug with the black jumper to the right of the orange plug in this pic.
If I remember correct, I used the GS jumper on the Aristo plug because I didn't get the jumper or it was broken or something.
Then you have to rearrange the pins in the plug to make it look like it does in this pic.
once you do that the dash lights light up and the shiftlock will release the shifter.
Hope this helps,
Ryan
Hope this helps,
Ryan
I believe silverGS is correct and I had my plugs wrong. It is the one to the right of the Orange plug as he states. I did this swap over 5 years ago and my memory just isn't what it use to be. If you look in my pictures the plug in my car is gray and is what came with my Aristo front clip.
I will try to get some pictures up of the other connector as soon as I can but I will not be home untill late tonight.
Sorry for the miss information but I am getting old
Ben
I am still not able to get my shift selector out of park and its one of the only things really holding me back from driving my car.
So, any advice you guys can give me, especially any details on the pin/wiring swap for the shift selector Id really appreciate it.
Thanks guys
Cory
Thanks guys
Cory
Hey guys....its great to see everyone helping each other out.....you don't see this on most forums....
I've done the Nissan thing years ago before everyone had SR's....sold it to get out of debt but when my wife said she missed my BOV a couple weeks ago I knew I had to do something new.
I am getting ready to do this swap and want to know if there is a good prep thread on here to help me make sure I have all my ducks in a row....
I'll be following this thread as well.....also, I work at a Lexus dealership and I'm more then welcome to helping with anything I can......thanks in advance guys!
https://www.clublexus.com/forums/gs-...e-for-now.html
Its running, I can get the car out of park, and sounds healthy.
Only issues im still having :
1) Car is running PIG rich. No higher than 12's and goes straight to 10's (or lower) with any acceleration. There must be something fuel wise different between my stock GS300 fuel pump/regulator and the 2jzgte fuel system thats causing it to run so rich.
Im going to search around to find out what else I need to do to my fuel system to prevent it from running so rich.
2) traction light is on (couldnt get the traction system to work, bah, guess Ill just have to pull the bulbs in the cluster)
That's normal for them to run rich, Toyota programs them to run on the richer side, cruising Im between 14.7-15.1 on the A/F ... when I nail it, it goes to 10.0 but levels off
Its UBER rich.
I have never seen my guage go higher than 12. Even cruising its like.. 11.3.
When it idles its like.. 10-11's and I can see black smoke (unburnt fuel) dumping out the exhaust.
Something is wrong, I can only imagine that my stock gs300 fuel pressure regulator is somehow increasing the fuel pressure higher than what the aristo 2jzgte needs.
This is not rich.
Its UBER rich.
Its UBER rich.
