Alternative Air Filters for 98 GS300
My mechanic recommended buying a K&S air filter for my 98 GS 300 that would fit in the stock air intake. I have not been able to find one for the 98+ GS series. Does anyone know if they are available or what other higher-performance air filters would fit without having to replace the intake system?
filter and borla
Dennis,
you already ahve the borla, so by adding a filter like K&N would not increase the noise that much, according to several members. but the performance level would raise a notch, and you can feel the increase.
the problem is when i called KN a few months ago, they did not have one readfy for the gs430. you might want to check with them again.
summit racing sells the k&n for gs400 at $30, not bad.
let me lknow if you coming this direction, thanks.
Will GS4 filter fit GS3?
GS4will:
Thanks for the info. Do you know if the filter for the 98+ GS4 will fit a 98+ GS3? I have found listings for 98+ GS4 K&Ns and pre-98 GS3 K&Ns, but not for a 98+ GS3.
Re: Will GS4 filter fit GS3?
MSDS also makes an intake for the GS. In my opinion, go with K&N. Just wanted to add for completeness
http://www.msdsinc.com/new_lexusgs400.htm
Noise a concern?
Are you going with the drop in K&N, over the Swift Racing's ECU/Intake set-up due to noise?
For the noise, I was thinking that lining the fender with sound insulation material for cars, would really cut down the wind tunnel noise big time. Even applying it to the inside surface of the heat shield.
