rear end gear change GS 430 2nd gen
Like I posted in the other thread, they don't have the numerically lower gears I'm looking for, but gear sets go for $175-$225.
http://www.jawsgear.com/Ring_And_Pin...7.5-IRS_Supra/
MKIII, MKIV, GS300/400/430 all have 8" gears and the Turbo 6spd MKIV's have bigger 8.7" gears.
You can swap a whole 8.7" 6-spd MKIV pumpkin which has 3.13's into a GS as long as you get the axleshafts with it. That would get you a slightly longer gear, but probably not enough to be worth hassling with unless you were doing it to gain the LSD as well.
