Anyone here with an Invidia Midpipe?
I might get an Invidia Midpipe from a local person but had some questions.
1. Anyone install it themselves? Was it a lot of work?
2. Will installing it cause a CEL?
3. Any tips or warning I should know of?
4. Do I need to remove the O2 sensor?
Also got emissions inspection next month lol. Thanks if you help out!
1. Not a ton of work but w jackstands and a helping hand it can be done.
2. No CEL
3. The o2 sensor is in a PIA location.
4. Yes you need to remove 2.
Check out the thread i made for when I installed it. I love mine w just the stock axle back. A nice subtle change. Let me know if you had the same issue as me. My pipes were banging on the lower brace bar. I ended up replacing the spring bolts w fixed bolts and used washers to move my brace bar lower, giving me more clearance. I purchased my pipes new.
2. No CEL
2. No CEL
2. No CEL
I installed the midpipes by myself. I'm a loner.
Simple unbolt and bolt procedures. Requires lots of elbow grease.
I had mine on jackstands and it was good enough for me. About half way through unbolting the pipes, I cried (not literally) and went to borrow my dad's impact gun. Piece of cake from then on.
Not if done correctly.
One thing that freaked me the heck out that I was not aware of: the first time driving your car after installation, you will notice white smoke from your rear and an frightening foul smell coming from it, I guess it's normal.
Use an impact gun to cut the install time in half, save yourself from knicks, bruises, frustration and tears.
Yes. Long walled one. And get yourself a breaker bar.
I may have pics you are looking for. I took pics during my install for a DIY but got too lazy half way through.
Done the midpipe by myself as well. You might need new crush gaskets for the front two flanges since you got it used. Rear donut gasket is usually okay to reuse.
Good luck.
Good luck.
1. Yes. A lift makes things 10x easier, as does a helping hand.
2. If done right, no.
3. Don't kill yourself working under your car when it's on nothing but jackstands.
4. Yes, and you need a special O2 sensor removal socket, which you can get from most auto parts stores.
Wait until you pass emissions, then install the midpipe.
You can find the crush gaskets at any local auto parts store. The person I purchased the midpipe from gave me one extra and told me I can find them at O'Reily for about $6.
I'm installing the pipe when I wake up tomorrow at like 10. My plan is to remove the two braces underneath, remove the back two bolts, then the front four, have the pipe on the floor and remove the O2 sensors and reverse the process. Does this sound about right? Also, what do you people mean by "doing it right", I won't get a CEL?
