Fujitsobo exhaust for Gs300
I think that it's important that folks should know that this exhaust system will fit all 1998-2005 GS models regardless of powerplant chosen. Because it fits our GS430 just fine.
One of the main differences that I wish Fujitsubo would have done during their manufacturing is to bevel out their flange to accept the OEM style copper doughnut at the cat. Instead they have you mash a metal gasket to the cat that has the Lexus flange beveled which offers barely enough meat at the top and bottom of the flange to make a good seal. It would have been a perfect fit if Fujitsubo beveled their mating surface. In my opinion, if there ever was to be an exhaust leak, this is where it would originate.
I took a 90° die grinder with a 3M Roloc coarse disc pad to it but that still doesn't add more meat to the OEM cat flange.
Lexus used a design with a circular copper washer, that's their design for the exhaust seal that's tight around the pipe whereas most A/M exhaust manufacturers, such as in this case Fujitsubo use a very common design, a 2 hole exhaust gasket. We've all seen this type of gasket before but Lexus "trimmed" or designed their flange differently at the top and bottom leaving a very little mating surface to compress anything other than the OEM design was intended.
You'll be able to see what I'm talking about once you have to seperate the new Fujitsubo pipe from the Lexus' cat. You can inspect the 2 hole gasket and see just how thin it is in these two areas. It's minimal at best.
Another thing I noticed is that the Right side or Passenger side muffler is canted counter-clockwise just enough to notice. I saw it when finished with my install. I stood back and saw the right muffler wasn't square with the other muffler.
What I did was to loosen both mufflers and twist them to their stop of the bolt holes. The left or drivers side muffler I tweaked one way and the passenger side I twisted clockwise.
If there was any more need to make this type of adjustment, I'd grind down and enlongate the holes of each mating pair as to have level vision of the mufflers at the rear of the vehicle.
You can see what I'm talking about in the first picture posted above, it looks like the passenger muffler is at an angle compared to the drivers side muffler which looks level.
Look, if I wasn't picky, I wouldn't have bought a Lexus.
![](http://image.importtuner.com/f/17807367/impp_0904_09_z+1998_lexus_gs_400_power_pages+y_pipe.jpg)
on clublexus
also, the catback is rated 85db
look at the first picture in post #19,
On my car the canted right muffler is corrected so a pic wouldn't do you any good to see what I was talking about.
yea I know it's pretty quiet but just loud enough. Especially at start up.
I don't want to hear the exhaust when on a road trip like a speed boat, it sounds quiet enough to make the journey still enjoyable by all who are aboard.
Yeah I'm interested to see how much it changes when I turn the boost up. The velocity of the exhaust is usually quite a bit different so I'm expecting it be louder under higher boost. If its this quite at low boost and idle yet moderately loud under high boost......that equals perfection! lol
