HELP. Fi/c installed, will not rev above 3500rpm
I just intalled Turbonetics T66 with 3" intercooler kit. Car runs with lean afr with just stock ecu but will rev pass 3500rpm. Now have the fi/c installed. Set the MAF map with 9%. It idle at 14.5-14.8 afr. Run fine till 3500rpm than the front end shakes like it running out of fuel. This is just before boost start to kick in. I'm running 8lb of boost right now. Needing some help how to tune fi/c to run right.
Everything is stock right now with 1.3mm hg. The hesitage only happen just before boost. Even with stock fuel system, it should suport 8lb boost.
I'm in Joplin, MO. It's very hard to find someone who knows how to tune fic. If anyone close to Joplin can tune please give me message.
Like you mentioned you shouldn't be having a fuel system problem at such low boost levels, and when you disconnect the FIC it revs better, that is most definatly the tuning (or the wiring) of the FIC.
Do you have the MAF input set to voltage or percentage? And are you sure you have the igniter settings correct? Wasted Spark 1&6 2&5 3&4
99 GS3, can you elaborate a litle more on the igniter settings. Is this something I can adjust with the fi.c software?
EliststK, I been reading alot of your posts. It has been very helpful. Thanks for all the info. I'm getting ready to change the spark plugs. I'm using NGK BKR7EIV-11. What should I gap them at or just install them pre-gap?
I would get this
http://www.boomslang.us/aemfic.htm
I installed a FIC on my car and it ran fine with this harness takes the guess work out of it.
I have moved on to a V-Pro I only used my harness for a couple of days. I would sell it for $200. Or you can just order one, he is in Columbia MO so you could get it in a day no problem.
Ben
Ben
I would get this
Ben
Ben
