Bad MAF = Throttle Lag?
#31
I used redline injector cleaner in the past, worked great. It also slightly boosts octane as well.
I think the process is like put in the redline cleaner when you are at 1/4 tank, drive it till nearly empty. Then fill up.
This way you dont have to wait for a whole tank of gas to finish before the redline cleaner reaches the injectors.
#32
The purpose of those fuel injector additives is to reduce carbon build-up. If your car is pinging/running lean then it may help. This will not solve your throttle lag. My hypothesis would be to check your TPS with a Lab Scope. Doing a snap test with a Lab Scope will show you the TPS's glitch. As I mentioned before, if you don't have proper tools, you won't have proper diagnostics.
Allaretake
Performance & Maintenance
06-03-10 02:36 PM
LittleMous
25
02-25-08 12:40 PM
