Air Intake question
Air Intake question
Hey, I recently installed a short ram intake into my GS300. I didn't run into any problems except that the new intake only had 2 inlets (for EVAP hosing etc), while the old one had 3. Would it be ok if I took the hosing coming off the engine (I'm guessing crank case) and the hosing coming from the EVAP unit (I'm guessing its the one that vacuums out the gas fumes) and put them into a T joint connected to the intake? I figured that the 3rd, larger gauge, hose coming off the throttle body would need its own inlet. Would this cause any problems?
Thanks in advance,
Ellis
Thanks in advance,
Ellis
Ah ok. You seem really knowledgeable about these kinds of things so maybe you could answer another question. Is the duct that is above the radiator there because that area is a low air pressure zone, which makes it easier for the stock intake to suck in air? Or is it there to physically pick up and force air into the stock intake. I ask this because I left it in place with my ram intake, thinking that it physically picks up air and that it would force it into the area where the filter is.
First, the most part of hot air will take underhood,
Secondly, aluminum piping underhood will heat up air also ...
The regular intake with a box for the filter is made of the plastic providing good thermoisolation, besides it is tight and takes away air from street. Instead of the regular filter it is possible to put K&N with smaller resistance, but even it won't give you any notable power increase.
YODAONE
04-14-16 09:00 PM
