Need help with jdm aristo twin turbo
My JDM 98 Aristo TT have been giving off white smoke at start up in the mornings for some time now and it seems to be getting thicker of late. I have ask a few local mechanics and they all say it is the turbos are getting bad. I have been given some suggestions as to how to fix the issue:-
Here are the suggestions that have been offered:-
1. Just get another set of JDM turbos as they are direct bolt on
2. Get USDM Supra turbos - they say these may not be direct bolt on
3. Get 2 aftermarket turbos because OEM turbos are crap
4. Change to a single Turbo
This car is a daily driver so I am seeking a solution that is good on gas but at the same time can give a punch whenever I need to.
The engine is pretty much stock except for the intake and the blow-off-valve both have been changed to HKS aftermarket.
I have been trying figure out which way to go with fixing the car but not sure, and I am seeking some advise from my fellow clublexus members.
Thanks in advance.
Thanks in advance.
A friend of mine had the same problem with his MKIV his is a daily driver as well. Every morning that he would turn on the car he would get white smoke as well. It turn out to be his turbos so he went single that fixed his problem.
The problem with this JZ-TT engine's are the stock twins. From what i've heard from people that own JZ-TT VVT-i or non VVT-i engines the stock twins are the first to go. It really sucks. So what you can do is re-build the stock twins or buy new twins or go single.
Hope it help's
Hope it help's
Yeah since the smoke is white check coolant levels just in case, when the engine is cold its normal, but after it warms up it should go away. BTW I see you live in NY, how did you get by registering for use on the road? Just curious as I want to get something from Japan myself.
The car is actually in Jamaica WI (Caribbean) -where I spend a lot of time, it has never been in the US, it was shipped directly from Japan to Jamaica.
Smoke on startup means worn valve stem seals, constant smoke is bad turbos. So if it smokes after startup then the turbos are gone if its just when you startup in the morning or if the car has been sitting for a while its the valve stem seals.
here is a DIY that should help you
http://www.mkivsupra.net/vbb/showthr...al-Replacement
I have a tool, its from matco and you can pull your plug, pressurize your cylnder, take this tool, hit it with a hammer and you can do all your seals while still on the car and takes about 2 hours for your first time and the tool is around $85 for the set
My next question would be what other parts should be changed when doing the replacement of valve stem seals?
I live in NY but the Aristo is actually in Jamaica WI.
that is correct, if its only on startup its the valve stem seals. i saw something on titan motorsports site the other day with the parts needed to fix this but i cannot find it now....
Thanks for the info on the tool. Could you tell if it is the metric version of this tool that will work on the 2JZ engine?
Thanks for pointing this out, I will definitely have the valve stem seals replaced. Hopefully that will solve the problem.
Thanks for DIY link. This will definitely come in handy.
Looks like this but mine came 2 sizes. http://buy1.snapon.com/catalog/item....&group_ID=1578
I agree what he said^^^ also before you put it all back together check all the hoses around and make sure nothing else needs replaced it's better to do it all at once than go back and redo it again.
