IS350 with PPE header owner
Anybody with the 350 with PPE Header run the 1/4 mile yet? Im about to run the strip next week just curious on the some times. I ran 13.5/13.6 completely stock. But now i have the Joe z intake,PPE with HFC,and exhaust. Also be on my 19's which are 3 piece and heavier than my stock.
Depend on the weather and get all your junks out of the trunk. Anything that add weight to the car lolz, spare tire, jack, tools, cleaning kits... i meant everything lolz... manual book Dont forget to have 1/4 tank of gas or lower...keep the rpm under 1k. turn off VSC. So far i only did 1/8 of a mile at Irwindale back then only intake and exhaust.... consistently got 8.7 to 8.9... and was very hot up to the mid 90 ... that 3/4 of gas lolz....will be back anytime soon... and 1/4 opens... Have fun
a better judgement would be to see if it improves your MPH. Times are really subjective to perfect launches and a whole host of conditions. MPH is a pretty constant output given that its a fixed length 1430 ft and an auto to boot.
simple calculations can be done to determine whp improvements by comparing 1/4 mph speeds. When I was testing my intake, it produced 1.5 mph difference in trap speeds which indicated about 7-9 whp improvements. Sure enough, the dyno proved a 8 whp gain.
ITs the best way to measure engine output without a dyno.
Previous speed traps were around 102mph complety stock. Guess im what till Oct. hit and it gets like 30 out. Try to maybe put my stock setup back on and see what happens from there. Even my friend two evo were running 14s for good part of the night till there last run both hit 13.5. I only ran 4 runs then called it a night.
Lil4cyl
Southeast
10-29-12 04:17 PM
P Rock
Performance
02-25-12 10:20 AM
