What is in the upper air box?
Old 09-19-11 | 09:49 AM
APynckel's Avatar
APynckel
Default What is in the upper air box?
What is the mesh / device in the upper portion of the OEM airbox?
Old 09-19-11 | 10:52 AM
Kurtz's Avatar
Kurtz
Do you mean the carbon filter?
If so it's..well... a carbon filter.
Don't remove it, it won't help... (and one person showed a 1hp loss on a dyno from removing it, though that's certainly within the margin of error)
Old 09-19-11 | 10:53 AM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
Originally Posted by 2006 IS250/350 New Car Features Book (NM0140U, Page EG-24, Section 2)
A charcoal filter, which adsorbs the HC that accumulates in the intake system when the engine is stopped,
is used in the air cleaner case in order to reduce evaporative emissions. This filter is maintenance-free.
From the NCF Book.
Jeff
Old 09-19-11 | 11:31 AM
APynckel's Avatar
APynckel
How does it not restrict airflow?
Old 09-19-11 | 11:55 AM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
Air passes through it very readily.
Jeff
Old 09-19-11 | 11:58 AM
APynckel's Avatar
APynckel
Jeff
It's still an object between the atmosphere and the engine... Unless it acts to laminarize flow, it would only make the air passing through it more turbulent.
Old 09-19-11 | 12:33 PM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
That's a distinct possibility. I have a feeling Lexus may have also worked some features into the shape of the airbox to help direct flow through that section with the filter as well. It's hard to know exactly without doing some flow tests on it, however I do know from experience with other Toyota models and with the IS as Kurtz mentioned, that removing the HC filter in the airbox doesn't provide any performance boost, at least not with the stock airbox/intake setup. If you changed the factors involved (airbox shape/intake length/etc.) perhaps you may get into a situation where removing this filter would provide a benefit.
That being said, I haven't heard of issues with removing it either, so if you do choose to remove it, there shouldn't be any problems.
Jeff
MrHarris (04-11-22)
Old 09-19-11 | 01:55 PM
Gville350's Avatar
Gville350
I was looking at the charcoal filter just yesterday and was hoping it was something that would pop in/out of there...but that's not gonna happen. I'd leave it in there personally.
jafoo
09-18-21 11:27 AM
YODAONE
04-14-19 03:40 PM
gone2morro
05-16-18 01:13 PM
iceman1117
07-30-06 04:51 PM
