2jz gte stock twins
10-24-11, 08:10 PM
2jz gte stock twins
Hey guys, I have a 99 gs400 and I'm planning on doing the 2jzgte swap.
Does anyone know how much power can be made with just the stock twins? I've been hearing a mix of numbers ranging from 350whp -450whp with the stock twins. How truthful is that?
10-25-11, 11:28 AM
between 350-400whp is realistic with bolt ons and pump fuel, depending on the condition of your engine. 450whp maybe with high octane fuel and a tune
10-25-11, 11:48 AM
Quote:
Originally Posted by
Bippu147
Thanks for the input. I guess the question now is if that's enough power to at least trap somewhere near 105++
10-25-11, 02:11 PM
maybe...the GS is a pretty heavy car
10-25-11, 05:40 PM
I hit factory speed cut in the 1/4 with stock twins before I had Nitrous. So that is about 112 before the traps.
Ben
10-25-11, 06:35 PM
Burton
Ben
Impressive. How much boost were you running?
10-27-11, 11:00 AM
i make 390 to the wheels at 18.5 psi with the stock jdm twins
i haven't ran at the track and i have a speed cut defencer sitting on my counter at home
10-27-11, 05:15 PM
Noon question- what is a speed cut defencer?
10-27-11, 05:47 PM
It knock away the speed cut sensor so you can drive until u feel like stopping or until you can't handle anymore....
11-04-11, 02:02 PM
When I had my supra on stock twins full bpu the car ran between 402whp and 450rwhp depending on weather and quality of pump fuel. Jdm twins are smaller ceramic props. They spool faster but have less top end.
11-04-11, 05:38 PM
Yea. I hear the us twins make more power?
11-04-11, 08:16 PM
The VVTi turbo's are larger than the US spec turbos, and steel wheel.
11-05-11, 10:44 PM
Bippu147
Since when?
11-06-11, 09:46 AM
since always.
also, the ceramic JDM turbo's have always been larger than the US steels. Bigger compressor, smaller a/r.
11-10-11, 07:16 AM
Bippu147
since always.
The VVTI turbos are still ceramic. The only turbos that have steel turbine wheels are the USDM supra turbos.
