F Sport questions
Yeah...for something like springs/shocks I might be a little more inclined to want the warranty (but only a little, based on how much I've seen folks quote dealers charging for install on those)... but intake/exhaust are just pipes with no moving parts, not even close to worth paying a few hundred bucks for "more warranty" on given there's nothing to really go bad on either.
http://is.sewellparts.com/accessorie...2006/1853.html - F-Sport intake
http://www.l-tunedparts.com/product/?id=2804 - Joe Z intake
I wouldn't be worried about the warranty on the individual items (intake & exhaust), I would be more concerned with the installation of said items and how they could affect my car. For example, if you had a shop completely butcher the installation of an exhaust, the worst thing that could result is a louder sound and loss of back pressure. The intake, on the other hand, if installed incorrectly could have huge ramifications for your car, as it handles all the air going in to the engine. Bottom line, if you want peace of mind, have the intake installed by the dealer, but you could have a shop install the exhaust.
Unless the person doing the install is illiterate it's virtually impossible to cause a serious problem by "installing it wrong" with either of them.
Am I right to say that the intake sound and effect does not come into play until you hit 3k rpm ? If so, is it still worth getting?
Also, would it be a good idea to upgrade our shocks to F sport if we drop on H&R springs?
Thanks
Thanks
No, I understand the basic nature of both parts. My suggestion was based on a worst case scenario - more could go wrong with an an intake not being installed properly versus an exhaust. Once you leave the confines of a dealership, one can never assume anything - especially because recourse is far more limited.
Yeah... not really seeing it...
A local shop is still a business, so they still have a legal responsibility to fix anything they damage... and the opportunity to damage anything is still very very limited in installing an intake. It's really tough to screw it up if you've ever worked on a car before (which presumably someone working in a shop has)
Heck, take the lower airbox out of the equation (which while time consuming isn't really mechanical at all, which is why I usually recommend the Joe Z intake over the F-sport) and the intake takes even less time to install than the exhaust... and the exhaust only takes 15 minutes with ramps and a couple wrenches... less with a real shop.
Even with folks just doing their own installs in their driveways the worst "problem" I've ever seen from an F-sport intake install was "forgot to plug the MAF back in" which is fixed in literally 30 seconds, for free.
Don't get me wrong, an intake install is simple and so is an exhaust. However, hypothetically speaking again, if an intake were to come loose from the throttle body, wouldn't that pose a risk to your car's performance and reliability? In that same vein, if an exhaust were to come loose, what's the worst that could happen? You would loose back pressure. That is my point!
And now back to our regularly scheduled program..........
Uh...do you know why they'd be taken to court?
Because they do have an obligation to do something.
otherwise you'd have no case.
By all means, please cite some for us.
Dealerships have far more more to lose, as they tend to open on the premise of being a long term fixture in their business communities, so getting things right is a bit more important.
Apart from the ridiculous suggestion the shop would close down rather than pay a small claims case your scenarios of possible issues are way wrong too.
If the intake came off the TB you'd get some unmetered air coming in, your dash would light up like a christmas tree with check engine and check VSC lights, and you'd likely pull over and take it to the shop again (or just look under your hood, since the issue would be obvious). Even if you kept driving it the engine would likely go into limp mode and run pig rich for safety...so you'd get bad mileage till you fixed it and not much else.
Folks have posted about exactly that happening in the past when they did their own install and didn't secure one of the silicone sleeves correctly.
No damage though.
On the other hand- if part of your exhaust fell off, it could shred your tire, or those of someone behind you, and cause a 10 car accident. Of course again that'd require a pretty damn incompetent shop, since they'd have to fail to both secure the hangars correctly and fail to bolt the pieces together correctly.
But anyway, please lemme know the names of all these shops going bankrupt over small claims cases for improperly installed intake! (a cite to the court case for each would be great too)
Dude, this could go on for days so let's just squash it. Let me take the high road by saying we'll agree to disagree.
Now back to the last relevant post - I think the car would look great with H&R springs; however, from what I have seen you might have a bit of gap in the front. Although, I'm sure some would choose to disagree with me.
