What to do!? Cheapest Real HP gains w/o Turbo
I want to do an NA Drift build for my IS but i dont want to do exhaust/header & definitely dont want to go Boost right now....So what else can i do to get some real HP gains? What is the most cost effective but HP gaining upgrades?
You dont want to go boost and you dont want to install headers/exhaust but you want HP gains That makes zero sense my friend. If you think theres anything else you can do, I recommend you get to searchin.
Bro, just do a GTE swap and do a BPU setup, this will guarantee you reliability and you'll have more than enough hp to slide. If you do a NA-T build, you should stay away from kits and piece together your own setup. You can choose different brands and it can possibly even be cheaper than buying a turbo kit. The GE can hold a lot of power, you just need to buy quality parts and not be a cheap *** like some people do when they want to boost their car.
if you unplug all your vacuum lines its a 25hp gain
and if you swap your fuel return and fuel-to lines thats like another 15
but on a real note, Nitrous Oxide its amazing stuff
Vacuum lines?
ive never heard of unplugging all of your vacuum lines what are they used for? what are vacuum lines? swap the fuel lines from OEM to ?
Bpu?
A 2JZGTE swap from a Supra. BPU ( basic performance upgrades) full exhaust, intake, boost controller. I wouldnt go with that but its possible. I say that because the GE block doesnt have oil squirters so if you put a GTE head on it will have the squirter holes. Its too much of a hassle for such little hp, you'll be better of just swapping out the GE internals for GTE's. The GE head is proven to hold 600+.
Nice
Nice ok i like that didnt know GE heads were that strong? so the GE top end and bottom end is actually pretty strong? i think thats what ill do keep it simple keep the GE head n just get the GTE internals....thx 4 the direction!
Oops I meant the bottom end can hold 600+ but the head will will fine tho. Look at this thread
https://www.clublexus.com/forums/per...r-600-whp.html
Cheap yet reliable and effective:
drop in air filter,,, i suggest Blitz- suprastore.com
Cam Gear and tuning- suprastore.com
Apexi WS2 exhaust- hopupracing.com
total: less than $1000 with tuning time
HP: about 30-40
HP: about 30-40
Questions in need of Answers
http://www.precisecontacts.com/cars.html
check out that link...
Why would you swap in a 2JZ-GE stock cylinder head?
What is the Electromotive Tec3?
