So hopefully this is my last problem WOT problem in GTE
OK so i have pretty much sorted out all my bugs from my conversion now except this one!!
If i floor it off the mark in 1st gear it revs out and drives like a NA no pull wha so ever
Now driving along if i floor it it bogs down and goes nowere
Now if i try both problems with the throttle not quite at the floor i get a decent pull like its supposed to but i have to constantly feather the throttle to keep it in the sweet spot otherwise it bogs down shudders and carrys on but doing this im also anly at 3/4 throttle
So whats the Go![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
im trying to get this sorted befor friday as im booked in for a dyno tune and to have my new blitz sbc id fitted
So whats the Go
So whats the Go
Long story short he did a leakdown and it turns out he had multiple valves not sealing correctly anymore. New headgasket, valve job, and head deck the cars runs flawless afterwards.
Did you ever do a leakdown? I know i mentioned it another thread of yours but I forgot what the issue was.
Leakdown testing will find the flaws in what ever the issue is, such as cooling system, valves, headgasket, rings, etc..
I would have thought it would be constant too.
I rode in and drove his car a few times while he was having the issues. And it was exactly as you describe. If you floored it from a stop it felt like it wasn't turbo, if you eased in the pedal steady while you were rolling already it would boost great until you got to WOT and it would fall flat again.
He also was confused for a while because some days it would run really good and others it just felt like it was not even turbo'd.
Not saying you have the same problem. But the symptoms you describe are spot on to his. (I hope you don't have the same problem, although 2j's are easy to pull the head on, way easier than the M52 I helped him pull out as the bimmers have the I6 slanted at a 45 degree angle in the car to lower the center of gravity, what a pain!)
Not being constant is what lead the tuner to suggest that his problem was electrical/coil/ignition issues, but it turns out it wasn't. The head was fixed many months ago and it's runs fantastic in all rpm's all the time now.
Hope you get it figured out soon, so you can enjoy your swap..
if you could monitor the TPS while driving , you may see the fly buy wire backing out the percentage even though you have the pedal to the floor, Im expericing this and wondering if you are too?
Neil64
Performance
08-19-04 08:21 PM
