GS400/430 - Megan Mount Kit Petition
As far as motor mounts are concerned. I have well over 500hp and 500 tq on my motor. Motor mounts don't like it. It ripped in less than 2 years. And I rarely pushed the motor that hard. Only time it got pushed to the limit was on the dyno. I would love to have motor mounts that wouldn't rip, but my overall experience is that once more solid mounts are place, the noise and vibration get transmitted to the cabin much more. Would be interested in the mounts.
If there was only a way to have the best of both worlds....now I'm dreaming.
In the start my were slight vi-by, before long it wasn't even noticeable. The noise level? no complaints there either. it was my wifes car to top it off, and she wanted it to remain comfortable.
First off, Lexus/Toyota is NOT a Honda.
Honda stock mounts SUCK. That's what 1,457 companies make aftermarket mounts to replace the stock ones.
and as for Megan Racing. I would NOT use any of their parts if they were Free. I've been around long enough to witness the crap they copy, i mean make.
if you want REAL mounts made... that are engineered and properly done. Talk to Figs (a sponsor) or Hasport.
I'm not sure if you've heard of hardrace, but I think you have lol. Those guys make some kickass bushings. I'm not 110% sure if megan bought those guys, or vice versa, or if they are just plain out sharing technology. But if Megan is using hardraces materials I'M ALL IN!
The only reason why I suggested megan is because they already cater to the SC crowed w/ mounts, if you guys want to commission another manufacture by all means say so,
Thanks,
Joel
I don't necessarily think Honda mounts are bad. I think it has more to do with the fact that a lot of Honda guys mod and drive more aggressively than us Toyota owners.
I'm all for a stiffer mount, but only if the car needs it. There is no reason why someone with a stock GS300 would need such a thing. The transmission shifts slow enough that even with stiff engine mounts, the shifts will still be mushy. On the other hand, someone with 400whp+ probably doesn't care about vibrations.
I was actually looking into getting a manufacturer to build some custom poly mounts. The stock mounts are fine if you are...well, stock. Once you increase the performance, there should be stronger mounts installed(which currently there are none for the 2GS). Why do the Supra owners upgrade the stock mounts to the TRD units, other aftermarket poly, or just straight solid mounts? When they launch hard, the engine will literally rip the mounts in half! On my previous setup in my white GS, the engine would torque over about 2" when running full out on the dyno. This can cause a variety of issues. The torquing of the engine may cause the couplers to pop off or the engine can bang against the shock towers.
I know most of the 2GS drivers here don't do anything near this level, but the guys over on My.IS are constantly tearing their motor mounts in half. Especially those that have swapped over to a 6 speed V160 and are launching their cars hard.
I cant even speculate a price of a mount set but I'm certain a "better," or improved mount for less would be great if it could happen.
When I have driven with the hood off the car I can see the motor move quite dramatically no doubt. I am running fresh oem engine, trans, and subframe/diff mounts. I really don't want solid mounts as having a solid one piece driveshaft without guibo/isolators and a heavy clutch the driveline already transmits enough to the chassis, I prefer the rubber to absorb some of the shock from shifting. The more solid you start making everything the more likely to start breaking something. The energy has to go somewhere.
I could just make the Supra mounts work on the GS with a little modification, it wouldn't be that big of a deal, it's always nice to have aftermarket options but once someone has a built a car to level of needing solid mounts then they are likely to have the means or someone with the means to one-off a solution.
I would be more inclined to install a quality engine damper in my car before getting solid mounts. Not an ebay damper with hard plastic bushings inside, but an actual valved absorber..
Mike not to combat your knowledge, but you guys need to stop being stuck in the dinosaur age, and realize things are changing. Look at hyundai, they were crap in the 80's & 90's, they almost left the US Entirely. They made many changes, and improvements, and it shows.
Thanks,
Joel
I am not knocking stuff made over seas, most (not all) everyone's stuff is made there. That's why its affordable because made in USA costs a lot more money.
However, engine mounts need to be engineered, tested and the right urethane compound used in order to achieve the right hardness for the vehicle.
I think Figs would have a good shot also at getting this done. And the fact that Mike makes the stuff and engineers it. I say support a vendor FIRST!
Team SNS
Club Lexus Vendor Marketplace
316
04-23-15 06:22 PM
BayAreaLex
12-30-12 07:57 PM
BayAreaLex
12-13-12 03:39 PM
