99 gs300 swap i need help!
whats up everyone...its been almost a yr now since ive messed around with my swap...heres the issue im having....the ecu they sent me with my swap does not work...im not sure if i wired it wrong or what...but when i hook my stock ecu up to it..it fires up right away..any one know what could be the problem...?...also i need to find a driveshaft...heres some pics i took yesterday..
Yeah man I remember your build. You haven't been working on it?
It was well discussed and directed in the thread at the time that you have an immobilizer ecu, which is the problem but is not really a big deal at all.
You have two easy options that cost roughly the same:
1- Call a local mobile locksmith that has the Toyota programmer to come out and re-flash the cars cabin security ecu and then your current key with work will with the ecu just fine. (approx $125-$250)
2-Just buy a non-immobilizer ecu (approx $100-$200) There have been a couple go through the classifieds since you've been working on this car..
Hope you get it worked out soon, sucks you haven't been driving your swap yet..
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
k..im having a hard time finding a locksmith near me that can do this..
also ive been looking for the ecu with the non immobolizer part...cant find one for sell..
anyone know where i can buy one..?
Ok long shot but can any one help with mine. 01 gs300 aristo swap. Will not crank over. I have a non immobilizer ecu switched over termination caps body to block ground and trans to body ground on. Have power to starter have power to b+ wire in f60 ecu plug all lights on the dash come on. But wont crank over and im pretty sure fuel pump isnt working what am i missing going crazy
