Need supercharger for my IS350
#48
well I found a ball bearing gt40 for sale in the local forums that would make for a nice rear mount setup.....just gotta get it going.
I definitely dont think you'll be seeing ANYONE with sustained boost levels above 7 psi without doing internal strengthening. The motor just isnt going to handle it.
http://www.toyotanation.com/forum/10...-flywheel.html
About an FE, not an FSE. Heavily modified but states block can be left alone for the most part.
#49
Since there aren't any aftermarket alternatives to our stock injectors, I've heard the term "bored-out" injectors before but don't truly understand what all it entails. To me that sounds like increasing the fuel delivery ability of an injector; but I don't know if that will hinder driveability or not. Thoughts on this?
#50
Not to mention the FE didnt use half port and half direct injection.
#51
The more I thought about it, modifying the stock DI injector wouldn't help, as it plays hell with the pulse and pattern. Might loose efficiency in the quest for more fuel.
The port injector is a fairly common unit (also used on the IS-F), but increasing its flow capability does no good since the engine is 100% on the DI injectors at WOT.
The trick would be to keep the port injectors open longer, at a higher rpm. The 80% duty cycle that HKS is seeing is pushing the limits for all but the best injectors, and for sure too long for an in cylinder unit like the one we have.
The computer's too smart for my own good.
#52
why couldnt you do some sort of inline injector at the manifold?? treat it like nitrous, window switches and WOT only.
I think my mapecu has control for additional injectors and some multi stage nitrous activation too.
#53
The trick is really going to be adding another HKS Fcon or Map ECU to the port injectors. have it's own tune. Grrrrr.....this will be impossible to tune.
The only full EMS that I know of that controls 12 injectors is Motec $8k. The injector driver is @ $4k. All the Motec sensors are $2k. But for that price I'll have a full ECU / EMS that will and can emulate and talk Cann bus...
Pocket change ... Fkkkkkkkkkkkk
Im thinking for that much money I could just send my car to Tom's in Japan and have them tune it. Then ship it back.
#54
I know the one guy in the UK running one is running a JDM vehicle to do it.
I wasn't aware they could program the port injectors to have their own tune on the stock ECU though- otherwise I'm not sure how that'd fix your fuel problem.
#55
I thought the TOMs kit (besides only running like 5.5 psi) required a JDM ECU in the car?
It was just a pun'
I have a JDM ECU in my poss. right now. Not sure what the differance is tho. Or what the big deal is. I have plugged it up and ran it for @ 200 miles with no CEL's or any other issues.
hmmmm( makes HKS350 think what cool features it might unlock) Like rolling the windows up from remote, lol j/king
#57
It was just a pun'
The JDM ecu doesn't have the same sort of encryption the US one does
or
it does, but a JDM company reprogramming the JDM ECU is able to crack said encryption without running afoul of the DMCA here in the US.
#58
My awnser is....... They look the same, muhahahaha
No really I'd guess the encryption is not as heavy as the US market.
My US ECU has tamper proof screws, safety measures to ensure I don't get into it. The JDM ECU just phillip head screws.
Something makes me think these JDM ECU are as easy for the Japanses to flash as the Chevy camero ECU is to flash for us.
