supercharger for my is300
I'm thinking of getting a supercharger for my 05 Is300
only thing is that it's automatic and I want to put in something that'll give me power that the engine could handle right now. the car only has 97 k so at some point later down the line I will do a swap. and if not getting a supercharger then just going in an exhaust system and keeping it classy :-)
what does everybody think?
First I would do a compression test to see if everything is good and worth boosting. After you get the numbers then start looking. How much power are you trying to make? Their isn't alot of supercharger kits out there anymore and you would pretty much have to piece together a kit. What is your budget on this? its alot of things to factor in. Will you be doing the install or having a shop do it? The list goes on and on haha. Supercharging and Turbo gets very expensive so if your pockets aren't ready for it then I would just do an exhaust and be classy like you mentioned.
First I would do a compression test to see if everything is good and worth boosting. After you get the numbers then start looking. How much power are you trying to make? Their isn't alot of supercharger kits out there anymore and you would pretty much have to piece together a kit. What is your budget on this? Oooits alot of things to factor in. Will you be doing the install or having a shop do it? The list goes on and on haha. Supercharging and Turbo gets very expensive so if your pockets aren't ready for it then I would just do an exhaust and be classy like you mentioned.
what kind of swap are you talking about? if you are going to go turbo down the road, why would you waste your money on a supercharger kit? you won't be able to use much from that kit on the turbo kit. Save your money and just do it right the first time...
As in rebuilding the engine or getting one thats factory boosted
Superchargers on these cars wont make nearly as much power as a turbo. Driftmotion or Suprastore sell "budget kits" that are made in china, but they work, i would just change the wastegate for a name brand tial or turbosmart. DM sells for $1500 and use a garrett turbo, and suprastore sells them for $1800 i believe. add this kit and aem fic controller and have a decently quick car for a cheap budget.
IMO turbo is the way to go on a 2JZ.
Really appreciate it
No. compression test every cylinder. Then have a cylinder leak down test done. if these are withing factory standards, it will be ok to turbo the engine. if they are below more than 3% of factory, id play it safe and tear the engine down and rebuild. My old SC300 got 9 pounds of boost, engine was within factory spec and boom it went bye bye. The only reason it went by is bc it had over 165000 miles on it when i boosted it. it just took out the rings. so play it safe, do it right.
arien_one2
IS - 1st Gen (2001-2005)
27
09-30-04 09:37 AM
