Project beater gs drift *****: 2jzgte, single, r154, shave,flush, you get the picture
#46
i dont see the aristo listed but these may fit
http://www.rhdjapan.com/uras-super-tie-rod-27305
is he supposed to be actually putting them out?
http://www.rhdjapan.com/uras-steerin...and-fc3s-27038
as for the knuckles, they arent really needed, so Im not sure if they are being released or not.
#47
pretty sure those arent available for the aristo.. I was referring to these..
#51
#52
If you have a GS300 and you are looking to do the manual swap, it is pretty straight forward. Its a direct bolt on to the 2JZ block. You will have to use the subframe mount from the auto tranny. Of course you just have to cut a bigger hole on the tranny tunnel to fit the shifter. The hardest part is drilling the firewall for the slave cylinder. Its pretty much the same thing as doing it on the SC300. The only difference is that on the GS you dont have a premade template on the firewall to show you where to drill the holes. Good luck!
#53
VIP161;7792355]If you have a GS300 and you are looking to do the manual swap, it is pretty straight forward. Its a direct bolt on to the 2JZ block
#54
