Weapon r secret intake
Old 03-26-12, 12:04 AM
hermzxd45
hermzxd45's Avatar
Default Weapon r secret intake
Hey this is my first post and I need some help. I recently purchased a weaponr secret intake for my 03' Lexus gs300. When I put it on today my idle was off lower than usual. And when I tried to rev it I could like major lag. I also tried to drive it but felt it had no power very laggy when I hit the throttle. Can anybody give some pointers to what is wrong with this?
Old 03-28-12, 07:39 AM
NEbiker10
NEbiker10's Avatar
yah return it...its a POS
Old 03-28-12, 08:48 AM
sakataj
sakataj's Avatar
i cannot....
its a secret, even to the manufacturer
get rid of it
Old 03-28-12, 09:22 AM
hermzxd45
hermzxd45's Avatar
Wow. Really it's that bad. Damn.
Old 04-09-12, 12:29 AM
818GS
818GS's Avatar
did you try resetting the ecu?
Old 04-09-12, 11:22 PM
themccoy14
themccoy14's Avatar
I'm guessing something isn't plugged in or there's a seriously loose coupler. Check your connections on your fancy new intake. I can't imagine that adding an intake would make it run worse...
Old 04-10-12, 05:36 AM
99 GS3
99 GS3's Avatar
Like mentioned try resetting the ecu. But yes these cars don't respond to an intake like 90's Honda's do. Just a pipe and filter can cause hesitation when taking off from a stop and slight leaning. To get any benefit you really need something like a safc or neo to compensate.
The stock intake system works very well. And if you have no other engine mods I would stick withthe stock one.
Old 04-21-12, 09:08 PM
neojungle1
neojungle1's Avatar
i dont see nothing wrong with my it did trip check engine light after a reset it went away ive been driving with it on for over a two yr no problem what so ever in the winter month it has more of a pick up ...but it a really a little more noisy but nothing to bad ... in my own opinion...
Old 03-18-14, 09:50 PM
bran4f33r
bran4f33r's Avatar
did you ever fix this problem I'm getting the same thing from Weapon r and my 2000 300
Old 03-19-14, 08:32 AM
CharlieD93
CharlieD93's Avatar
I have the weapon R intake on my 98 GS3 and it runs and drives fine, even has a nice high pitch sound when in higher RPM's. Sounds like a whistle, I personally like it. I didn't see any real gains though.
LiLS
Performance
12
01-18-11 12:33 PM
Bigwun07
Performance
03-21-08 06:50 PM
mex lex
Performance
01-05-07 06:07 AM
cklex
07-05-01 06:55 AM
Quick Reply: Weapon r secret intake
