f-sport exhaust... passenger side longer??
hi guys,
I just installed my f-sport exhaust today... came w/ no instruction but pretty easy to play with.. please help me verified make sure i did everything correct..
1--muffler don't have a mark of L or R... I installed the muffler w/ short pipe on the passenger side
2- two exhaust hanger. (came w/ exhaust). I use to the hanger on the end of Y pipe.. I didn't change the four hanger that use to hold the muffler..
3.. Problem or not??? I notice the passenger side sticking out more then the driver side. maybe 1" or so. is this normal??? I try to push the muffler back and forth but do no good...
I love my new sound...
I believe you were suppose to change out the two hangers.. Look here for the instructions and see if you did em right. =P
http://is.sewellparts.com/pdf/PTR0853090.pdf
My f sport exhaust is about the same on each side. Your sposed to use the hangers that came with it on the end with the mufflers and use stock ones on the y pipe area.
You may wanna take a look and make sure all of your pieces are bolted together correctly aswell.
